testing the alternator - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-23-2013, 10:41 PM
mikosiko mikosiko is offline
Vehicle: 2003 Dodge Ram 1500 SLT 2wd
mikosiko is on a distinguished road
Default testing the alternator
Where do you put the leads, where do you set your multimeter on and what reading should I get... I have good voltage on battery while driving, good voltage right after stopping, 14 volts while running at idle and 12 without engine running, but let it set for a bit and I have a draw somewhere and I just wanted to start with testing the alternator... Thanks
Last edited by mikosiko; 02-23-2013 at 11:10 PM. Reason: to make more explanatory with voltages
Old 02-23-2013, 11:34 PM
Rep:2954
On older vehicles, i just start it up, then disconnect the negative battery cable, if it keeps running, i try the headlights for a little bit, if still runs the problem is not the alternator
checking for parasitic draw
Old 02-24-2013, 10:08 AM
Ok did the check the charging and it charges fine, now I am on to checking for parasitic draw... If there are any tips out there while I do it send them on in, Ill check back here in a bit...Thanks
