Old 02-24-2013, 01:39 AM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
Default Crew Cab with 3.55s and 6800lb trailer
Looking at a 28-29' bunkhouse for next year around 5200lbs dry, 6800 lbs loaded, wondering what my towing experience will be like. I already know from some trial runs with borrowed trailers, albeit lighter, that I canexpect about 8-10mpg, but should i belooking for a lighter trailer considering my max trailer wieght is 8500lbs less any gear and passengers in the truck?
Let me know your experiences
Old 02-24-2013, 02:15 AM
Rep:2657
I don't have any experience to share
i have read that using a Weight Distribution Hitch makes all the difference in the world
equalizes the weight on the towing vehicle
http://www.etrailer.com/faq-weightdistribution.aspx
Old 02-24-2013, 02:45 AM
h2oman's Avatar
h2oman h2oman is offline
Trim Level: Express 4X4
Rep:358
You will be fine.
http://www.ramforumz.com/showthread....911#post832911
333Half the beast
I used to be
Old 02-24-2013, 10:54 AM
BCRAM BCRAM is offline
Vehicle: 2012 RAM 1500 QC 4x4
BCRAM is on a distinguished road
I assume that this is a Ram 1500 CC? You should be ok pulling the trailer. Just watch you do not exceed max truck payload as the loaded trailer tongue weight is usually 10-12% which should be around 650-700 lbs for your trailer.
On average with the 1500 CC, the payload is about 1600 lbs so this leaves about 800-900 lbs of payload. Factor in a full tank of gas, people, gear in the bed, spare tire, the actual trailer hitch weight itself, and deduct from available payload.
See this recent thread for a bit more info
http://www.ramforumz.com/showthread.php?t=133835
Old 02-24-2013, 12:38 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
Yes you should do just fine and as GTYankee indicates a weight distribution hitch is a worth having and I would get a WD & Anti Trailer Sway combo. It is best not to bump up against your max tow ratings, rather allow a margin and with the numbers you are reporting you have a nice margin.
Old 02-25-2013, 10:20 AM
sandawilliams's Avatar
sandawilliams sandawilliams is offline
Vehicle: 2014 2500
Rep:12
sandawilliams is on a distinguished road
Default towing
I have towed my 33' trailer over 25000 miles with my quadcab, hemi, and 3.55's. Trailer loaded weighs 7100#. No problems. a WDH is a must. Also be aware that if you tow a lot you should use air bags to better level the truck and trailer. I noticed cupping on all four tires. After replacing the tires I installed the bags and leveled the truck. No more cupping.
I live in Colorado so everything is either uphill or downhill and this truck pulls like a charm.
Hope this helps.
Old 03-02-2013, 10:56 PM
Rep:14
Hope this helps.
Was planning on airlift 1000s as soon as the purse strings loosen up for trailer stuff. Seem to be the only ones that survive the winter other than the more expensive tlcs.
Old 03-03-2013, 01:11 AM
h2oman's Avatar
Rep:358
Airlifts work great. You'll be fine with them.
333Half the beast
I used to be
