Old 02-24-2013, 11:11 AM
tomballram tomballram is offline
Vehicle: 2012 ram 1500 express
Trim Level: express
Color: bright white clear coat
tomballram is on a distinguished road
Default express 2012 underhood light instalation
Hi, I have a 2012 crew cab express I bought the light and wire loom to install the underhood light. Does anyone have pics of the instalation? What is used to attahe the light to the hood, how do you route the wire loom? Where do you plug the loom in? do you have to remove the hood insulation before assembly? Thank you, this is my first post. Tom
Old 02-24-2013, 07:33 PM
Techno Tim Techno Tim is offline
Vehicle: 2012 Ram Express
Trim Level: Reg Cab Express
Color: True Blue Pearl
Rep:29
Techno Tim is on a distinguished road
It is very easy to do, you should not need any pictures. The connector for the light will be in the passenger side cowl area right at the firewall and will have a termination cap protecting the contacts. DO NOT try to pry out any of the large plastic clips that hold the hood insulation on: it's not necessary and they will break leaving the little plastic tang to rattle forever around inside the hood. Just feed the harness thru the cutout for the light housing until it comes out near the connector. You will need a couple of fir tree clips to hold the light housing to the underside of the hood. They are available at any auto parts store usually in the section with all the hard-to-find do-dads. If you don't know what they look like, google "fir tree clips" under images and you'll probably recognize them.
As I recall, the light will only sit comfortably one way with enough harness to reach the connector. When you have everything layed out right, it should become obvious where the harness clips in, etc.
Be sure to check that the light goes out when you close the hood.
That's it. Takes all of five minutes once you have the fir tree clips.
HTH
Old 02-25-2013, 08:02 AM
skull1 skull1 is offline
Vehicle: 2012 Dodge Ram Crewcab
Trim Level: Longhorn
Color: Cherry Red
skull1 is on a distinguished road
Most of the wiring harnesses come with the clips pre-installed in the right places. Makes it even easier. Be careful getting the cap off the plug. It can be easy to break.
Old 02-25-2013, 03:22 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
I would like to see pics of this mod. do they come in colors? where did you get it from?
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-19-2013, 10:57 AM
jpierce0723's Avatar
jpierce0723 jpierce0723 is offline
Vehicle: 2012 Dodge Ram 1500 2wd
Rep:19
jpierce0723 is on a distinguished road
Pictures please i would like to do this also
Old 04-19-2013, 11:16 AM
Asur Asur is offline
Vehicle: .
Rep:4373
don't really need pictures, its the under hood light, just buy off ebay or at the dealer the light and cable, take 5 min to install, very easy.
Here you can find the parts numbers and more info here
http://www.ramforumz.com/showthread.php?t=92135
