Old 02-24-2013, 06:56 PM
Hondo13Reba's Avatar
Hondo13Reba Hondo13Reba is offline
Vehicle: 2012 RAM 1500 Express 4x4
Hondo13Reba is on a distinguished road
Default Tires?
I plan on getting the bilstien 5100's as soon as i get back from deployment, to level the truck out. Now I was wondering a better look or way to go when it comes to the tires. 33x 12.5 R20's or 305 55R20's, also what size spacer do you think I will need? Thanks for the help in advance!
" Don't Sing It, Bring It "
Old 02-26-2013, 09:39 AM
travis55's Avatar
travis55 travis55 is offline
Vehicle: 2012 Dodge Ram 1500 Sport
Color: Mineral Gray Metallic
travis55 is on a distinguished road
My buddy has a 2010 big horn and he leveled his and he just recently installed 285/65/20 BFG A/T KO on his truck and they fit great! they measure out to be about 34.5in tall, his username is 6988june on the forum idk if he has any pic up yet tho hes new to the forum but thats the size tire i would go with i also have the bilsteins and im going that route, you wont regret it
Old 02-26-2013, 07:26 PM
EXPRESS25C's Avatar
EXPRESS25C EXPRESS25C is offline
Vehicle: 2012 Dodge Ram Express RCSB
Trim Level: RCSB - Express 25C
Color: Diamond Black
Rep:83
EXPRESS25C will become famous soon enough
295/60/20 ... had mine on the stock alloy's (8 inch wide wheel) with no rub/spacers. 34.45 diameter and 12.13 wide.
"Excess is Best"
Old 02-27-2013, 08:51 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
33x12.50x20 and 305/55/20 are basically the same size. You will need a 1/4" spacer to run either. As mentioned above, 285/65/20 is an option that you could run without spacers. It's going to be taller but not as wide as the two sizes you mentioned. 295/60/20 or 295/65/20 are good options too but depending on whether you have the 8" or 9" wide rim, you will still probably need the spacers. EXPRESS25C was able to run 295/60/20 on the 8" rims with no spacers but if if you have the 9" rims I think you will need them. Get all that, lol? Hope it helps!
