Antifreeze leaking - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 02-24-2013, 08:50 PM
bum4x4 bum4x4 is offline
Color: Austin tan
bum4x4 is on a distinguished road
Default Antifreeze leaking
01 5.2L, My sons truck is leaking antifreeze looks like its coming from the thermostat housing, hard to see due to the a/c and alternator blocking it.
Question is : do I just remove the alternator to get to the thermostat housing? And could a leak on the water pump cause antifreeze to look like it is leaking toward the manifold?
Thanks guys
Old 02-24-2013, 09:02 PM
Resident Technician
Rep:1915
I don't take anything off to get to the housing, but it's probably going to be easier for someone that doesn't do this every day to remove it. Yes, a leaking stat could cause it to look like you have a water pump leak.
Old 03-16-2013, 03:56 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
I take the alt off and unbolt the AC compressor and lay it over to the side. NOTE: there is a very short PITA hose from the water pump to the intake that most people don't change because it is hard to get to and harder to see. that was the cause of my leak that I thought was the thermostat housing or WP.
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 03-16-2013, 04:08 PM
Color: Austin tan
NOTE: there is a very short PITA hose from the water pump to the intake that most people don't change because it is hard to get to and harder to see. that was the cause of my leak that I thought was the thermostat housing or WP.[/QUOTE]
Well hell... already finished the job, and your right I didn't notice the hose. Hopefully the leak was coming from the housing.
Old 10-17-2013, 08:08 AM
Hawkins9578 Hawkins9578 is offline
Vehicle: 1996 Dodge Ram 1500
Hawkins9578 is on a distinguished road
I know this is an old thread, but I have a similar problem, its leaking antifreeze above the water pump, the weaphole is dry So i think the water pump is fine, also about the same time it started leaking the serpintine belt started squeaking im wondering if maybe the bearings inside the water pump are blown, I dont want to replace the Water pump unless I have too, but I want the squeaking to stop Thanks
If the mud aint flyin you aint tryin
Old 10-17-2013, 10:12 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
If the bearing are going bad in the water pump you'll be able to feel a grinding when turning it by hand. You'll have to take the belt off, to do that. Or, you could get a mechanics stethoscope and put your prob to the water pump while it's running and listen for the squeak.
