Old 02-25-2013, 03:43 AM
T-Rob T-Rob is offline
Vehicle: 2010 1500 Crew Cab Sport
T-Rob is on a distinguished road
Default Wheel spacer size????
Hey, I'm Tyler. I drive a all white with black accent addons 2010 Ram 1500 sport crew cab. I have added a leveling kit, tailgate extender, bushwacker bolt on style fender flares, a brush guard grille, and some Mickey Thompson Baja STZ. Here's my question, the tires are stock but the largest they could put on their, I wanna say 28 or 30 maybe?? Anyway would I be able to add a 2 inch wheel spacer without rubbing when turning??
Old 02-27-2013, 09:45 PM
JPartridgekk's Avatar
JPartridgekk JPartridgekk is offline
Vehicle: 2016 Ram Rebel
Trim Level: REBEL
Color: Granite Chrystal Metalic/Black
JPartridgekk is on a distinguished road
What size tire are you running? and are you running the stock wheels? What size leveling kit? There are a ton of guys on here that will be able to help you out but will need the above info.
2012 RAM 5.7 HEMI, Diablo Intune DCX, K&N cold air intake, 18" magnaflow exhaust, Carbon Fiber Shorty antenna, BAK INDUSTRIES Rollbak G2 bedcover, Spray in bedliner, XD Rockstars W/ 305/50R20 Nitto Terra Grapplers, Bilstein 5100's Set at 2.8, TGC 3/4" Rear Coil Spacer.
Old 03-03-2013, 08:13 PM
CRANKYPISTOL's Avatar
CRANKYPISTOL CRANKYPISTOL is offline
Vehicle: 2011 Ram 1500
Color: Mineral Gray
Rep:13
CRANKYPISTOL is on a distinguished road
I actually have a full set of Aluminum hub centric spacers in 1.5". I just think for me that the 5/16" looks better. I paid $160 for the set and used them for less than a week. Let me know if you want a deal on them!
I work for Goodyear as a store manager! If you have any tire questions feel free to ask. If I do not know, I will find out.
Old 03-03-2013, 09:30 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I'm a little confused. You said you put on Mickey Thompson STZ but then said the tires are stock? And then went on to say they were the biggest they could put on there. Sorry if I am misunderstanding but I just didn't get what you were saying. And when you say 28 or 30....are you talking about the tire height? If so they should be much taller than that. The stock 20" tire size is a 33" tire and the Rams will easily clear a 34" or even a 35" with the right rims or spacers. As for the spacers, I assume you are wanting to push your rims and tires out to sit closer to flush with the flares? As someone said above, let us know for sure what rims and tires you are running and maybe someone can help you out with the spacer info.
2wd level kit, help needed, wheel spacers
