Old 02-27-2013, 03:56 PM
Rep:1890
I watched as one of the guys used a air wrench to tighten the lug nuts on another guys Ram, that customer was very irritated as we watched it happening, there was a lot of LOUD cussing going on
Was there a torque stick on the end of it or just a regular socket?
Old 02-27-2013, 04:14 PM
Rep:2657
The guy was almost 50 feet away from where we stood, 4th rack from the door
so i would not venture a guess on that Randy
Just saw that he never used a torque wrench, just the air wrench
the Ram had the 20" chrome clads on it
Old 02-27-2013, 05:48 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Cliffords sick again...dog-gone-it!!! Keep us posted!!!
Ibram81, When wiring on anything, I always have a ground just for the thing you are adding. I never ground to frame. I always run dual wires, one hot, one ground, putting the ground where the battery grounds to engine block or where fuse block grounds. That way you never have one part using another's ground. More work, but huge difference in the end. And remember, the fuse protects the "wire" not the electrical device, so have the fuse sized properly to gauge of wire used to feed the electrical draw. Put the fuse as close as possible to the end of wire that hooks to power source. Simple things often over-looked. Just because it comes on doesn't mean its hooked up right.
Wishing Clifford a speedy fix!!!
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 02-27-2013, 09:16 PM
Hemi N Haw's Avatar
Hemi N Haw Hemi N Haw is offline
Vehicle: 2012 Ram 1500 Laramie Crew cab
Color: Bright White-W7
Rep:139
Hemi N Haw will become famous soon enoughHemi N Haw will become famous soon enough
Talking
Man Oh Man we got a sick Cliff here & all people wanna do is bash each other & talk illumination!!! Why God Why!!!!! Any ways right back asap cliff I wanna know what's got your truck all messed up. Just curios about that wiring harness mention from an earlier post & in addition doesn't that tune adjust shift points as well? Man I hope I'm wrong but hopefully your dealer mechanic doesn't try to pawn this issue on the p.c.m. being messed w/ then deny warranty claims. I hope that the tune doesn't leave any footprints. Anyways post back cause this type of issue w/ only 14 thou on the O.D. would press my hot button & have me thinking about driving said truck threw said dealers show room! But hey I'd never advocate such a thing!
Old 02-27-2013, 11:40 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
cliff is sick again what did I miss?
Thanks
Jeremiah
Discount Auto Performance
Old 02-28-2013, 09:16 AM
Rep:1890
So what would have the mechanic do if it is a PCM problem and the tune is in there? Are you saying Chrysler should warranty the PCM even though it's been altered? At that point, it seems like the company that coded the tune and the owner are responsible because they tampered with what the factory designed and installed.
Old 02-28-2013, 01:30 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
Hey, I've been moddifying cars for years. When I tune it, thats it. I know I'm writing off factory warranty protection. But I pay to play. I go in with my eyes open. And if I encounter a problem with the pcm, I go to the tuner with it and see what they say after diagnosing.
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 02-28-2013, 03:18 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
The new Hemi is pretty well tuned...I wish there was a way to just turn MDS off without a tuner...that's all I'd probably do.
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 02-28-2013, 03:58 PM
Clifford17 Clifford17 is offline
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
the dealer called me and the cam sensor and crank sensor went out of sync. they couldnt tell me why but they said it is all fixed and ready to pick up...
Old 02-28-2013, 04:12 PM
Asur Asur is offline
Vehicle: .
Rep:4373
That would be a good reason to have Misfires.
