Old 02-26-2013, 10:55 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Just throwing another hat in the ring. Check out Green performance filters, have read good things about them. Just read the CFM flow bench comparisons on Vararam's website. The Green filter smoked the K&N, and hung with or out-flowed the CAI's in the test, and it was in a stock airbox.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 02-27-2013, 03:55 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
The negative about Amsoil, is you cannot wash them in water, and they do not last forever. The rest you can wash in water/solution once they get real dirty.
Old 02-28-2013, 11:50 AM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2012 sport crew
Trim Level: sport crew
Rep:16
nfd538 is on a distinguished road
Who washes air filters in water? With the AMSoil you just hit it with compressed air. And nothing last forever.
BT catch can, 20% tint, Leer 100xl top, Aero 3030xl
Bilstein 5100, Duratracs 275x65x20 (winter), 20" SRT & 275x55x20 Nitto terra graps (summer), InTune DCX, MagHytech diff cover
Old 02-28-2013, 12:20 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The airaid dry filter(and others) you wash with mild dish soap and water, then rinse with water, then let dry.
Oiled type filters also are normally washed with mild dish soap and water, then rinse with water, then let dry. Then oiled.
Sean
Old 02-28-2013, 02:35 PM
ILuvaMyTrucka's Avatar
ILuvaMyTrucka ILuvaMyTrucka is offline
Vehicle: 2014 Ram 1500 4x4 CC
Color: Maximum Steel Metallic
Rep:38
ILuvaMyTrucka is on a distinguished road
I have been thinking about this as well and came across the following test that was done about 4 years ago. Makes me wonder about the K&N.
*** Link Removed ***
Current: BakFlip FiberMax, Optimum Opti-Coat 2.0, Pillar Tape Removed, Partial Debadge, Tinted Fronts to Match Rears (15%)
Future: TBD
Old 02-28-2013, 02:39 PM
snrusnak's Avatar
Rep:1385
Link is no good.
I bet I know what it is though, and it's probably a very skewed test that actually is meaningless....they've been posted before.
Sean
Old 02-28-2013, 03:10 PM
Rep:38
I couldn't get the link to work here, so I took the information to post on here.
SCOPE:
This report presents the results of an ISO 5011 test of several air filters designed for the GM Duramax Diesel. The test was independently performed under controlled conditions using a $285,000 machine at Testand Corp of Rhode Island (manufacturer of the machine). Arlen Spicer, a GM Duramax Diesel owner/enthusiast organized the test. Ken an employee of Testand offered to perform the tests at no charge. (These tests typically cost approx $1700.00 per filter). Ken, also a Diesel enthusiast and owner of a Ford Power Stroke Diesel, shared Arlen’s interest in performing an accurate unbiased test of different types and brands of diesel engine air filters. The filters used in the test were purchased retail and donated by Arlen and other individual Duramax Diesel owners. The detailed reports from the test have been compiled and are presented in the following pages. The final pages of this report present the interesting story how and why Arlen organized the test.
ISO 5011 Test:
The ISO 5011 Standard (formerly SAE J726) defines a precise filter test using precision measurements under controlled conditions. Temperature & humidity of the test dust and air used in the test are strictly monitored and controlled. As Arlen learned in attempting his own tests, there are many variables that can adversely affect filter test results. A small temperature change or a small change in humidity can cause the mass of a paper filter to change by several grams. To obtain an accurate measure of filter efficiency, it’s critical to know the EXACT amount of test dust being fed into the filter during the test. By following the ISO 5011 standard, a filter tested in Germany can be compared directly compared to another filter tested 5 years later in Rhode Island. The ISO 5011 filter test data for each filter is contained in two test reports; Capacity-Efficiency and Flow Restriction.
Capacity and Efficiency:
The Capacity and Efficiency test report presents the test results of feeding an initially clean filter with PTI Course Test Dust (dirt) at a constant rate and airflow. The course test dust has a specific distribution of particle sizes ranging from less than 2.5 microns to greater than 80 microns (see table below). Every filter is initially tested at 350 CFM and the Initial Restriction or differential pressure across the filter is recorded in IN-H20 (Inches of Water). The filter is then tested by feeding test dust at a nominal rate of 9.8 grams per minute with a constant airflow of 350 CFM. The test is continued until the flow restriction exceeds the Initial Restriction + 10 IN-H20. At this point the test is terminated and the amount dust passed through the filter - Accumulative Gain - is measured. Dirt passing through the filter is captured in the Test Station’s Post Filter. The exact amount of dirt passed is determined by measuring the before and after weight of the Post Filter. Similarly, the amount of dirt retained by the Filter under test - Accumulative Capacity – is measured by taking the difference between the before and after weights of the Filter. From these results the overall % Efficiency of the filter is calculated. This test also indicates how long a Filter will last before replacement is required (or cleaning for reusable filters).
Flow Restriction:
This report presents flow restriction of a clean filter resulting from an increasing airflow. The differential pressure restriction across the filter is reported in inches of water (IN H2O) versus Air Flow in cubic feet per minute CFM.
Data from these reports has been compiled and presented in the following bar graphs, Plots and data tables.
Filter Efficiency:
Filter efficiency is a measure of the filters overall ability to capture dirt.
Accumulative Capacity:
“Accumulative Capacity” is a measure of dirt holding/loading capacity before reaching the maximum restriction limit - Initial Restriction + 10 IN-H20.
Accumulative Gain:
"Accumulative Gain" is the total amount of dirt that passed through the filter during the test.
(Note: The Purolator was reported to have a seal malfunction during the test and passed more dirt than it would have with a good seal.)
Initial Restriction:
Initial Restriction is the Filter under test’s resistance to flow at 350 CFM.
Dirt Passed Versus Total Test Time
This graph shows each the duration of each filter’s test versus dirt passed (Accumulative Gain).
In the chart above it’s important to note the different test durations for each filter. The AC Delco filter test ran for 60 minutes before exceeding the restriction limit while the AMSOIL and K&N tests each ran for 20 and 24 minutes respectively before reaching max restriction. In 60 minutes the AC Filter accumulated 574gms of dirt and passed only 0.4gms. After only 24 minutes the K&N had accumulated 221gms of dirt but passed 7.0gms. Compared to the AC, the K&N “plugged up” nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt. See the data tables for a complete summary of these comparisons.
Dust Loading:
The dust loading curves show graphically how each filter responded to a constant 9.8 gms/min dust flow before reaching the maximum restriction limit.
It’s interesting to note the shape of these Dust Loading Curves. The AC and Baldwin filters each had near linear responses until reaching maximum restriction. Restriction for these filters increased at a constant rate versus the 9.8 gms/min dust feed rate. The other filters, most notably the oiled reusable types, had an exponential loading response before reaching maximum restriction. These filters had a lower initial restriction, but they became exponentially more restrictive under a constant flow of dirt. Also notice the length of the curves as it shows the relative test time for each filter (time to max restriction).
Restriction to Flow:
The Restriction to Flow curves graphically show how each “clean” filter responded to a steadily increasing flow of air up to 350 CFM.
The Flow Restriction response curves for each filter have the same basic shape. However, note how the AC Filter, which passed the smallest amount of dirt and had the highest dirt capacity and efficiency, also had the highest relative restriction to flow. The less efficient filters correspondingly had less restriction to flow. This illustrates the apparent trade-offs between optimizing a filter for dirt capturing ability and maximum airflow.
Test Data Tables:
To be consistent with common industry practice all filters were tested using PTI Course Test Dust. Course dust is more commonly used since it will produce higher % efficiency numbers.
The Story behind the test:
First of all, many thanks to Arlen Spicer and Ken at Testand for organizing and facilitating the test. Arlen is a professional Firefighter who also operates a small tree service on the side. The tree service is the reason he owns a diesel truck. This study was the result of nearly a year of work by Arlen to get accurate independent data on air filters for the GM Duramax Diesel. Arlen originally set out to build his own Filter Test Stand so that he could perform accurate, repeatable and independent measurements on the various filters available for the Duramax. Arlen questioned the claims made by aftermarket filter manufacturers that their filters were superior to the conventional OEM style paper filters. After spending many months, hours and a considerable amount of his own money, he learned first hand how difficult it was to perform an accurate air filter test. He found it was difficult to maintain all the necessary controls to insure an accurate measurement. It was at this juncture that Arlen received a call from Ken at Testand offering to perform the ISO 5011 test free of charge. Ken found Arlen’s idea for an independent comparison study very interesting and offered to do the ISO 5011 testing using one of Testand’s industrial Filter Test Machines. Arlen posted the news in an internet forum and immediately the offers by forum members to purchase and send filters for the test started rolling in. Some members purchased and donated filters and others made contributions to cover the expenses and the cost of shipping the filters to Teststand. It was truly a team effort. The end result is the top quality data presented in this report. The following is a quote from a post in the forum.
(Arlen) SPICER wrote,
“Now that I am not doing the tests and my objectivity is not necessary, let me explain my motivation. The reason I started this crusade was that I was seeing people spend a lot of money on aftermarket filters based on the word of a salesperson or based on the misleading, incomplete or outright deceiving information printed on boxes and in sales literature. Gentlemen and Ladies, Marketing and the lure of profit is VERY POWERFUL! It is amazing how many people believe that better airflow = more power! Unless you have modifications out the wazoo, a more porous filter will just dirty your oil! Some will say " I have used aftermarket brand X for XXX # years with no problems. The PROBLEM is you spent a chunk of ching on a product that not only DID NOT increase your horsepower, but also let in a lot of dirt while doing it! Now how much is a lot? ANY MORE THAN NECESSARY is TOO MUCH!
Others are persuaded by the claims of aftermarket manufacturers that their filters filter dirt "better than any other filter on the market." Sounds very enticing. To small timers like you and me, spending $1500 to test a filter sounds like a lot. But if you were a filter manufacturer and you believed your filter could filter dirt better than any other media on the market, wouldn't you want to prove it? Guess what. Test your filter vs. the OE paper. It will cost you $3000 and for that price you will have the data that you can use in your advertisements. Your investment will be returned a thousand fold! EASIER than shooting fish in a barrel! So why don't these manufacturers do this? Hmmm? Probably not because they would feel guilty about taking more market share.
Now I am not saying that ALL aftermarket filters are useless. A paper filter does not do well if directly wetted or muddy. It may collapse. This is why many off-road filters are foam. It is a compromise between filtering efficiency and protection from a collapsed filter. Now how many of our trucks collapse their filters from mud and water? However, if a filter is using "better airflow" as their marketing tool, remember this....Does it flow better? At very high airflow volumes, probably. BUT, Our trucks CAN'T flow that much air unless super-modified, so what is the point? The stock filter will flow MORE THAN ENOUGH AIR to give you ALL THE HORSEPOWER the engine has to give. And this remains true until the filter is dirty enough to trip the air filter life indicator. At that point performance will decline somewhat. Replace the filter and get on with it.
Hopefully the results of this test will do 2 things. Shed some light on the misleading marketing claims of some aftermarket manufacturers and/or give us new insight on products already on the market that are superior to our OE filter. I stand for truth and will eat my words publicly if my statements prove wrong. I appreciate all of the help and support that you members have offered in this project. It would simply be impossible without your help. A huge thanks to Ken at Testand for his willingness to take on this project. I would be spinning my wheels from here to eternity without his help… SPICER”
Future: TBD
Old 02-28-2013, 10:09 PM
snrusnak's Avatar
Rep:1385
Well, that certainly wasn't what I thought you were going to post. It looks like you actually found ALL the info. Most people post one graph(say the efficiency graph) and it makes it look like K&N is the worst filter on the market.
But you show all the info, which is really great to see.
Depending on your use, you can decide from this info which is best suited for you. It should make sense that the best performing filter in terms of airflow(K&N) captures the least amount of dirt...
Sean
Old 03-02-2013, 11:24 PM
Dmj Dmj is offline
Vehicle: 2006 Hemi 1500 sport
Trim Level: Sport QC 4x4
Color: Blue
Dmj is on a distinguished road
I just ordered the Airaid JR kit (tube & filter) with the dry filter off Amazon for $160. Should be here in a few days, hope I like it.
Anybody have any opinions before I put this kit on?
I had ordered the aFe drop in but then canceled the order and went with this kit
Old 03-02-2013, 11:58 PM
Dmj Dmj is offline
Color: Blue
Dyno results can be found at black bear performance for AEM, airaid, cai, k&n, and volant.
can also try
https://dl.dropbox.com/u/55742651/In...%20Results.pdf
I apologize in advance if link does not work.
I googled black bear performance cai test, from May 15 2012 and followed the link on the second page.
DON'T PAY ANY ATTENTION THAT IT'S A CHEVY TRUCK SITE!! lol
Edit... Sorry, these are for whole cai's besides for the Airaid jr which btw got the most gain
