Place your Ad Here!
Old 02-27-2013, 11:28 AM
quicksilve quicksilve is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Outdoorsman crew cab
Rep:17
quicksilve is on a distinguished road
Originally Posted by newfiebullet View Post
many guys use them, think they are closer to a 35...guy i knew had then on with a 2.5 level kit and it looked good.
Thanks a lot for the help.
Old 02-27-2013, 12:56 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
For an AT tire, I would look into the new Toyo AT2. Then I would look into BFG or Nitto Terra.
There are many others, but named the more common ones.
Because you have an 8.5" wide rim you are slightly better off than those with 9" wide rim
you actually have 3mm more to play with.
But I do not see why at 35" tire wont fit given you level the front a minimum of 2.5"
I'd also recommend getting some hub rings to make them snug on the hub of the truck
Originally Posted by quicksilve View Post
Hey guys I have a new set of 20 x 8.5 rock stars and looking to put a new set of rubber for the summer. I also have a rough country 2.5" front and 1.75" level kit going in this week. I am looking to fill in the wheel well with a good a/t tire. What is the biggest I can get without rubbing issues.
2012 ramm 1500 crew cab
Rim specs:
Wheel Part Number: XD77528586310
Size: 20 x 8.5
Diameter: 20
Width: 8.5
Lug Count: 5
Bolt Pattern: 5X5.5/150
Metric Bolt Pattern: 5x139.7/5x150
Offset: 10
Backspacing: 5.14
Center Bore: 110.5
Thanks.
sales@revelperformance.com
Old 02-27-2013, 03:45 PM
Rep:17
Looked at the toyo at 2 but they don't make it in a 285/65r20 but they do have it in a 305/55r20 according to the site though they recommend a 9.5" rim width. Also I called 4 wheel parts about ordering a hub ring but they said I didn't need one due to that the dodges are the only truck using a 5 by 5.5 bolt pattern.
Old 02-27-2013, 04:49 PM
newfiebullet's Avatar
newfiebullet newfiebullet is offline
Vehicle: 2015 Ram
Trim Level: sport
Rep:141
newfiebullet will become famous soon enoughnewfiebullet will become famous soon enough
hub rings really dont have anything to do with the lug pattern...your bore is 110.5 and the ram is 77.8, its just to get the rim to sit even around the hub and be completely centered.
2015 blacked out sport 4x4 qc
Old 02-27-2013, 05:14 PM
Revel Performance
Rep:1804
Yea, 285/65/20 is a BFG size tire among others.
Id look into 295/60/20 as well. Im sure AT2 and Terra come in that size. It is a 34.5" tire.
Otherwise the 305 will do.
Rams are not the only trucks using 5x5.5. I believe the older Fords use it too.
This is why I recommend it ^^^
Not 100% needed as the rims are and should be lug centric, but I like my wheels sitting on the hub
Old 02-27-2013, 10:58 PM
Rep:17
Smile
After calling about 20 local places and checking pretty much every website online I came across a place in BC that will ship to Newfoundland for free. I can 35 x 12.5 toyo open country at2 for $1700 taxes in. Best deal I can find and cheaper than the local stores are selling the bfg's at a smaller size.
Old 02-27-2013, 11:40 PM
Revel Performance
Rep:1804
Was it Sorat Wheels?
Old 02-28-2013, 06:18 AM
Vehicle: 2015 Ram
Trim Level: sport
Rep:141
i had mine from kx wheels in bc...didnt shop around enough...wasnt a bad price but i could have done better
Old 02-28-2013, 06:19 AM
Vehicle: 2015 Ram
Trim Level: sport
Rep:141
mr fast up there is hopefully gonna hook me up next time around haha
Old 02-28-2013, 06:21 AM
Vehicle: 2015 Ram
Trim Level: sport
Rep:141
o and the bfgs are 1790 at costco if u didnt wanna **** with shipping
