Door lock jitters - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 02-26-2013, 02:56 PM
stashu stashu is offline
Vehicle: 2017 Ram 1500 Tradesman 3.7
Rep:14
stashu is on a distinguished road
Default Door lock jitters
I have a 2012 RAM 1500 with manual door locks. I bought a AUTOLOC KL550 remote and 2 GT2000 13lb actuators. I just received them from
Summit Racing.. I hooked up the system to test everything and I am having some issues. Hopefully someone here had the same ones and can help.
Perhaps they are not loaded with a resistance? as they would be in actual use. Not sure.
Equipment
AutoLoc KL550 Remote w/built door lock relay
2 AutoLoc GT2000 13lb actuators. Only one is hooked up for the video.
I have a 12 volt DC power supply "30amp" to test the setup, and wired the connector(s) as per instructions.
RED, Brown/Blue ----constant 12 Volts
Black, Orange/Blue & Orange Green to Ground
When using the remote the actuators work but sometimes they jerk up and down, go up and then down, etc. I am not sure what is going on. When locking they go up and go down even when I release the remote button. See YouTube video.
Any help? Thanks
2017 RAM 1500 V6 Tradesman Reg Cab
Smoke Bug Shield, Westin bars, Bull Bar, Downey Tonneau Cover
Old 02-26-2013, 03:04 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Seems like low voltage, or bad connections. What do you have them powered by on the table?
2016 Challenger R/T Hemi 6-speed.
2012 Equinox 2.4...Wife's Ride
2014 RAM 3.6/8 speed/3.55 gears........Gone.
"Life's hard, it's harder if your stupid."
How would you know?
Old 02-26-2013, 03:13 PM
Rep:14
Using a Anstron 12 Volt 30amp PS----I used this for my mobile HAM radio set up at home.
I will check the connections, but prettey sure there are tight.
Even tried the other Actuator and the other remote, same thing.
Thanks for your input
Stash
Old 02-26-2013, 04:25 PM
oldhp's Avatar
Color: WHITE
Rep:902
Still seems to be low voltage, like your power source can't keep up. They work fine at first but then it goes down hill from there. Do the actuators themselves have to grounded? Do you have full charged 12v battery you could use?
How would you know?
Old 02-26-2013, 05:17 PM
keg184's Avatar
keg184 keg184 is offline
Vehicle: 2012 dodge ram
Color: red
keg184 is on a distinguished road
I used the Auto loc k2000 and it works fine. You must have both doors either locked or unlocked for it to work properly. Just manually lock or unlock them and try it. Mine have been installed 3 months and no problems. Also check to be sure the wiring colors are correct to both actuators, if not one will lock and the other unlock.
Old 02-26-2013, 07:08 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Agree with you, oldhp- seems like low or erratic voltage. Also could be insufficient amperage.
Old 03-01-2013, 07:33 PM
Rep:14
Thanks to all for your help. I called AutoLoc and talked to tech support. He said he has never seen anything like this and recommended I send everything back to Summit for a exchange, which I did. I'll let you know how the new parts work. They should be here mid week.
Thanks
Stashu
Old 03-01-2013, 08:12 PM
Vehicle: no car
Rep:3238
Thanks
Stashu
Yeah, watching your video again, something seems wrong there. Glad to hear they are standing behind it and sending you new ones. Keep us posted!
