Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy
loads with coil springs
. Fits all 2009-15 RAM 1500 including Ecodiesel and 2014-15 RAM 2500!
No modification required
; keep the coil springs. TLC also makes units for 02-13 RAM 2500 & 02-15 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™. Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 02-26-2013, 09:51 PM
JPartridgekk's Avatar
JPartridgekk JPartridgekk is offline
Vehicle: 2012 Ram Big Horn
Color: Mineral Gray Metallic Clearcoat
JPartridgekk is on a distinguished road
Default TLC With 6" lift?
I'm really wanting to put the TLC bags on my truck But i plan to lift my truck 6" sometime in the next year, will i be able to use TLC with the lift?
Also can the bags be used without a compressor with a valve stem. and still run a pressure gauge to the cab?
2012 RAM 5.7 HEMI, Diablo Intune DCX, K&N cold air intake, 18" magnaflow exhaust, Carbon Fiber Shorty antenna, BAK INDUSTRIES Rollbak G2 bedcover, Spray in bedliner, XD Rockstars W/ 305/50R20 Nitto Terra Grapplers, Bilstein 5100's Set at 2.8, TGC 3/4" Rear Coil Spacer.
Old 02-27-2013, 12:26 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
We are working on adapters to make TLC work with 4" and 6" lifted trucks (TLC does work with levelled and 2" lifts out of the box)
So far, it appears TLC is compatible with most lift kits except ProComp kits. If you send us an email, we'll contact when we have something ready.
Yes, you can use TLC without an air compressor. Most people seem to run the Shrader valve out to the rear bumper (there is a convenient factory hole next to the license plate). If you want to "T" it off and put a gauge in the cab, you can do that too.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500
Level Every Load with TotalLoadControl.com
Old 02-27-2013, 07:14 PM
bamahemi bamahemi is offline
Vehicle: 2009 Dodge Ram CC 1500 Laramie
Color: tan
bamahemi is on a distinguished road
jpat send me a PM
