Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 03-09-2013, 09:52 PM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Orange FRAM filters are GARBAGE
Originally Posted by RAMDJM View Post
I use regular oil, I have run regular oil in all my cars and bikes, guess because they get changed so much I don't see a point in wasting the money. I usually go about 5000km, And I run fram filters in everything, or wix if fram doesn't make a correct filter
There is nothing wrong with conventional motor oil. The modern dino oils are perfectly good.
Synthetic oil is just that much better
IF you have been using the FRAM orange, and/or lower end filters - you'll could do a much better job filtering your oil and increasing the drain interval by using better filters or synthetic.
Pop on to YOUtube or google up some info on Fram filters - they really are mediocre.
Old 03-09-2013, 09:55 PM
Trim Level: RT
Rep:136
There is nothing wrong with conventional motor oil. The modern dino formulations are perfectly good. Synthetic oil is that much better at fully minimizing engine wear and is suitable for longer drain intervals.
If you've been using the Orange FRAM filter - I can tell you they are wortheless at filtration. Cut one open OR get on youtube and view them or GOOGLE up some of the studies.
Lower end FRAM filters are garbage.
Old 03-09-2013, 10:06 PM
s1000rrhp s1000rrhp is offline
Vehicle: 2013 Dodge Ram
Rep:13
s1000rrhp is on a distinguished road
I wouldn't use fram they are one of the worst, along with toyota filters. In order wouldbe amsoil, wix, Mobil, then....
Old 03-09-2013, 10:21 PM
Trim Level: RT
Rep:136
Default Break in oil (factory fill) or routing change?
Originally Posted by rjmlakota View Post
So I just rolled 3000 miles, should I change my oil now, or wait till 5000 miles? My oil life shows I believe 71% still. I'm going to use the mobile 1 synthetic. Should I have any issues using this oil, or should I use something different?
Thanks,
RJ
If you are on break in (factory fill) oil, YES change the oil now and switch over to synthetic if you can afford it. Mobil 1 synthetic is fine, while not the absolute best synthetic, it's perfectly good. Mobil 1 Extended Performance is just a tad more robust. But use a good oil filter (avoid FRAMS) Mobil 1 filter, K&N filter or Amsoil oil filter.
Oil is not the place to pinch pennies on any personal expense item - anywhere.
Old 03-09-2013, 10:28 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
I'll throw my hat into the stay away from Fram filters. At one time, like eons ago, they were not too bad, but somewhere along the way the quality fell off considerably.
Old 03-09-2013, 11:26 PM
Rep:13
I had a demo on a bunch of filters and fram were among the worst along with toyota filters they use a paper liner.. Mobil were alright but the amsoil and wix were very well built and would definitely outlast the others. Hense amsoil also has a 25000mile life expectancy on them.
