lacking antifreeze - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-27-2013, 02:56 PM
5.91500 5.91500 is offline
Vehicle: 1999 Dodge Ram 1500 5.9LV8 4WD
Trim Level: ST Quad Cab
5.91500 is on a distinguished road
Default lacking antifreeze
i checked the hoses water pump and radiator but when the car is cold it leekes antifreeze did i miss anything and it dosnt smoke either
Old 02-27-2013, 03:04 PM
Resident Technician
Rep:1915
Leaks from where?
Old 02-27-2013, 08:23 PM
front of the engine but its only a dribble or two when its cold once its warm its fine
Old 02-28-2013, 12:23 PM
Resident Technician
Rep:1915
So what exactly is your question?
Old 02-28-2013, 03:31 PM
so in the morning i see little dribbles of antifreeze when i start it up on the ground when its cold but once it warms up it stop the water pump was replaced both hoses n radiator has no leaks and also engine dosent smoke to long so i dont think its a head gasket but the question is where else can it be coming from
Old 03-01-2013, 11:12 AM
Resident Technician
Rep:1915
The thermostat gasket and the gasket between the timing chain cover and block are the two most likely suspects.
Old 03-03-2013, 02:24 AM
KTM11's Avatar
KTM11 KTM11 is offline
Vehicle: 2001 Sport Ram 5.9l
KTM11 is on a distinguished road
Ramtech's right on the money. My timing chain cover had a shot gasket and it took me forever to track that thing down. Thermostats a little hard to get to on these trucks so if you tear into it to inspect a leak throw the $6 thermostat with a fresh gasket in there for peace of mind
CAI K&N Filter, 2" Skyjacker Coils, 2" Skyjacker Add a Leafs, BFG A/T
Old 03-03-2013, 05:11 PM
Boogert's Avatar
Boogert Boogert is offline
Vehicle: 2010 Ram 1500 Big Horn
Color: Pull Me Over Red
Boogert is on a distinguished road
water pump bypass hose?
