2013 Sport Projector headlight swap..?? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 02-27-2013, 06:13 PM
HOTRODHARLEY's Avatar
HOTRODHARLEY HOTRODHARLEY is offline
Vehicle: 2013 Ram factory order
Color: BLACK
Rep:256
HOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the rough
Default 2013 Sport Projector headlight swap..??
Has anyone swapped 2013 projector style headlights into a 2013 base style headlight truck..? Is it a direct hook up..?
I can get a set off ebay for a good price.
Belltech 3"/5" Lowering kit. Belltech Rear Swaybar, Flowmaster Y Pipe, Custom 4" Single Exhaust w/ 4" Race Magnaflow, 22" SRT10 Wheels, Moroso Catch Can, Undercover SE Tonneau Cover, Weathertech Techliner Bedliner, Diablosport Trinity w/ Hemifever Tune
Old 02-27-2013, 07:21 PM
QuickSilv3r QuickSilv3r is offline
Vehicle: '14 1500 Laramie Crew
Rep:13
QuickSilv3r is on a distinguished road
it is not a direct swap, the wiring is different between the non projectors and projectors.
do a quick search for Arth, he did a swap with 2013 projectors.
basic wiring info in this thread
http://www.ramforumz.com/showthread.php?t=124131&page=4
Old 02-27-2013, 07:25 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Vehicle: 2017 Ram 1500 Crew 4x4
Rep:1276
You can find him here.
Arth's threads on the topic...
http://www.ramforumz.com/showthread.php?t=126602
Big Red my old 2011 Sport
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
hes saying for a 2013 to a 2013 just a different headlight i would figure if its 2013 the right wires would be there cant see dodge rewiring a truck just for headligts
Old 02-27-2013, 07:26 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
Arth has 2009 not a 2013
Old 02-27-2013, 07:35 PM
Asur Asur is offline
Vehicle: .
Rep:4373
It depends, the first 2013's where coming out with the quad headlights, so the cabling might be diff. I don't think it will be a straight swap, and some modification will probably be needed.
Old 02-27-2013, 07:37 PM
Rep:13
True, but I believe that dodge uses a different wiring loom for the sport/laramie lighting than the lower models. The headlight part numbers are the same (for the express for example) for the 2012 and 2013, so the plugs on the headlight are the same. which would mean two plugs vs one plug for projectors.
(unless I'm incorrect on this. )
Old 02-27-2013, 09:17 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
Humm wonder if the wires for the correct plug are hidden in there let us know what you figure out
