LED Grille Lights Installed with Pics - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 03-22-2013, 08:48 PM
Outdoorsman2012 Outdoorsman2012 is offline
Vehicle: 2012 Ram Outdoorsman
Trim Level: Oudoorsman
Rep:39
Outdoorsman2012 is on a distinguished road
Default LED Grille Lights Installed with Pics
So I installed LED grille lights about two weeks ago. I'm not going to go through how I installed them because many have already. They are mounted behind the grill with a relay and an inline fuse. I did wire a switch that sits near where your right knee is on the drivers side. I wanted the switch because it is illegal in NY and many other states to run 6 lights at the same time. While I find this stupid I wanted to be able to shut them off if needed. If you have any questions on the install I will help as I did take pictures but feel it may be extra and I can help with the wiring as its pretty straight forward. Only thing that wasn't explained in other threads was where go through the fire wall which I will post pics later if others are wondering. Now the pictures are hard to judge how these lights work so do yourself a favor and look at your lights in the dark on a cell phone and then compare before you look it will help understand how it doesn't show a lot of the light.
Stock Quad Lights with Low beams and Fogs
http://www.ramforumz.com/attachment....1&d=1363998844
Stock Quad Lights with High beams and Low beams
Led Lights Only
LED with Low and Fogs
Led with Highs and Low
http://www.ramforumz.com/attachment.php?
attachmentid=34341&stc=1&d=1363998844
Look at LEDs Only
http://www.ramforumz.com/attachment....1&d=1363999322
LEDs in Grile
Highs with LED
Highs with LED
LEDs with Low and Fogs
Old 03-23-2013, 04:59 PM
RcsbHemi's Avatar
RcsbHemi RcsbHemi is offline
Vehicle: 2010 Ram Rcsb
Trim Level: SLT 4x4 3.92
Color: PDM Metallic Gray
Rep:32
RcsbHemi is on a distinguished road
looks great. Where did you get those lights? They look very bright from the pics.
Mods: Magnaflow DOD14(resonator removed) line-x, tint, silverstars, tonno pro trifold tonneau, LED Licence plate and reverse bulbs, 2- 27w led fog lights behind grille. more to come........
Old 04-02-2013, 03:27 PM
Rep:39
They are from a company called tuff led lights. Found them on amazon and decided to call the company. Be careful if purchasing off amazon BC there is a cheap set with same pictures sold by diff dealer. Make sure seller is tuffledlightsdotcom. These lights are bright for sure but no real beam pattern. That is my only dissapoitment. Because of this I don't feel comfortable using them when on road. They are just to bright and will blind drivers. These are supposed to be bother 30 degree and 60 degree. I would just say there more like 45. From the reviews on amazon figures light was going to be wider but I did get a different light. Mine are not available from amazon I called up and spoke with owner and was looking for something like these. They are great light and for anyone who of roads or wants back up light they are deff a must but for on road use I would stay away. As for if I would by again prob not as it doesn't do what I was looking for but they are great lights and do throw off a lot of light. Have pissed off a couple people who decided it was a good idea to cut in front of me and then drive slow, needless to say they moved over quickly and let me continue on my way.
