Debadge= bad results. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-27-2013, 11:18 PM
fournierrandy's Avatar
fournierrandy fournierrandy is offline
Vehicle: 2011 RAM 2500
Rep:79
fournierrandy will become famous soon enough
Default Debadge= bad results.
Hey guys thought i would share this. I debadged my truck awhile back and noticed that there was some white shadow that would not come off. I tried everything i could think of to take it off and even took it to the body shop where they said it is in the paint. If you look in the pic with the badge above you can see that it is the letters of the badge. Strange i thought, but he said that there could of been space between the letters and the 3m tape and the body and with the sun beating on truck it could of superheated in behind where the air gap was therefore making the paint do this being a metallic paint. So i love the clean look but this makes me soooo mad and it is on both doors!! so i am now in the works of getting some custom badges made at billet badges.
This is the custom billet badge i am getting made up to cover it.
Too many after market parts!
Check out my build
http://www.ramforumz.com/showthread.php?t=132850
Old 02-28-2013, 01:37 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
Why not take it to a professional detailer and have them give you their opinion as to whether they can fix it?
295/60r20 Toyo Open Country AT Xtremes (previous tires were 285/65/20 BFG TA KO2s for 75k klms), Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 02-28-2013, 02:19 AM
Rep:79
They will not be able to fix as this is in the paint and not the clear coat, only way to get rid of it is repaint the door.
Check out my build
Old 02-28-2013, 09:15 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Wow, i have never seen that. Sorry about the bad results.. I think your new badges will look sweet though! At least they are different than the stockers and are "REAL" badges. Good looking truck, like the color alot!
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 02-28-2013, 09:57 AM
Giants89's Avatar
Giants89 Giants89 is offline
Vehicle: 2015 Ram 1500 Sport
Rep:48
Giants89 is on a distinguished road
How did you de badge your truck. Which method did you use?
DPF Deleted_H&S performance EGR Delete_5" turbo back exhaust_RaceMe tuned_35x12.5 Nitto's_Recon Tails & 3rd Brake light.
Old 02-28-2013, 11:03 AM
Rep:79
I used waxed dental floss to cut tape in behind badge, once the badge was removed i used very little heat on edges of tape to make it a bit more pliable to pull off and used goo gone to remove the left over glue. I did this for everybadge on my truck and all others were good but both of the heavy duty badges u can see letters. Like on the pictures you can see the E,V,Y,and D of the workds heavy duty. It is like this on both sides. It would not of been from the heat gun because i applied VERY little heat and i dont think i even used the heat gun on the passenger side and had the same result
Check out my build
Old 02-28-2013, 11:31 AM
Majiik Majiik is offline
Trim Level: 1500
Majiik is on a distinguished road
i have seen this before, i do understand you say this is the paint. this was on my trunk of my red dodge charger i owned. it appears the same as mine did. i had it buffed out and it worked.
Old 02-28-2013, 11:37 AM
Rep:79
i wish it would buff out, havent been able to get anything to work yet
Check out my build
Old 06-24-2013, 10:17 AM
Nemmisis1 Nemmisis1 is offline
Vehicle: 2013 Ram 1500 sport
Color: BLACK
Rep:51
Nemmisis1 will become famous soon enough
time for some sponser stickers....
Old 06-24-2013, 02:39 PM
AcadianRam's Avatar
AcadianRam AcadianRam is offline
Rep:53
AcadianRam will become famous soon enough
This is the first time I saw that also. But I will say what you plan on putting over looks good.
I did mine this week end with a fishing line. Chrome pieces came off real easy and I used a plastic body fill applier to help me get the rest off. Goo Gone was so worthless that I threw it over to the neighbours property. Went and got a eraser wheel and it worked like a charm, now that was worth the money.
