Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 02-27-2013, 11:56 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1276
Default Wind Whistle
Was on the road (as usual) today and it was exceptionally windy. Both my 11 and now my 13 have suffered from the same crosswind whistle. If I was to turn and drive nose into the wind or with wind the whistle disappears, only in a crosswind does she whistle like this. I've tried folding the mirrors, different antennas, open windows, closed windows, different heater settings, you name it and can't figure out what's causing it. I've talked with other local Ram owners and I know of 3 of us that all have the same issue.
Anyhow, here is the vid with my famous whistle!
Any ideas?
Big Red my old 2011 Sport
Old 02-28-2013, 12:19 AM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PXR Black
Rep:2477
Post
Mine does the same thing when there is a cross wind. It's somewhere on the passenger side. I just turn up my radio and it goes away. Seriously if we could figure this out I would be grateful as well.
sales@revelperformance.com
Old 02-28-2013, 12:25 AM
Stump3r's Avatar
Rep:1276
As of 3pm this afternoon I've done 10,000 km since November 1st. I seriously need to figure this out and make it go away.
Old 02-28-2013, 01:13 AM
Rep:2890
go old school
tape up the door seams on a windy day & see if the whistle stops
if it does, tear off a section of tape & drive again
tear off another section etc
When the whistle starts again, you know you found it
Old 02-28-2013, 01:33 AM
InDeepWaterBlue's Avatar
Rep:611
Antenna? But you replaced that, so maybe running boards....just an idea
Old 02-28-2013, 04:15 AM
carfigg50 carfigg50 is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
Trim Level: SLT Quad Cab
carfigg50 is on a distinguished road
I have a 2010, and mine started doing it at like 30,000. While I was driving I had my wife tug on all the doors and nothing but as soon as I pulled on the drivers door it stopped, so I'm almost sure its the weather stripping. As soon as I return from this deployment I'm going to have all the weather stripping replaced. I would check there.
Old 02-28-2013, 10:43 PM
mars1957 mars1957 is offline
Vehicle: 1996 and 2013 Ram
Trim Level: Laramie SLT, Laramie
Color: Black,Maximum Steel Metalic
mars1957 is on a distinguished road
I had this on my 96 ram passenger side and noticed the top alignment was different then the driver side. So I placed a jack under the passenger side door, loosened the hinge bolts and tipped the door a little then tyted the bolts. No more wind noise.
Old 02-28-2013, 10:46 PM
Stump3r's Avatar
Rep:1276
It's not the doors or door seals, they are quiet. The noise literally sounds like it's right in the dash just to the right of the Alpine sign!
Old 02-28-2013, 11:00 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
I would try removing the entire wiper assembly, arm and all.....both of them. There are enough surfaces and angle on them that it is possible to create a whistle under certain conditions and they are basically in the right area.
Another item to test is to run a piece of tape at the bottom of the windshield on to the plastic trim piece between the hood and the windshield. That would stop/reduce the air from passing by that seam.
brad
Interested in one of my mods?
Old 02-28-2013, 11:03 PM
Stump3r's Avatar
Rep:1276
I'm going to try the wiper thing tomorrow! Have to run out to a couple spots and have a good highway run. Let's hope it's windy!
