Old 03-02-2013, 08:12 PM
Ford Apostate Ford Apostate is offline
Vehicle: 2013 1500 4x4 CC 5'7" Rambox
Trim Level: Longhorn/8 Speed/Air
Color: Mineral Gray
Rep:17
Ford Apostate is on a distinguished road
Originally Posted by domesticman View Post
I figured I didn't need posi seeing as how I had my 4x4 package
Having 4x4 doesn't diminish the value of the anti-spin differential. It's an additive feature that goes hand in hand with 4x4. I would research more opinions on that while you can still change your order. I would think that would be a very popular feature up in Canada for you and your resale value. It doesn't add a lot of cost if you order it with it but retrofitting it is a different story.
Old 03-02-2013, 10:19 PM
domesticman domesticman is offline
Vehicle: '13 1500 CC 4x4 HEMI 8spd
domesticman is on a distinguished road
Originally Posted by Raybird View Post
You were able to order a SPORT, Hemi and air suspension? My dealer cannot order that package yet.
Ya definitely man. I paid for so many upgrades that it didn't fit on the bill of sale. I'm surprised you can't get the same package though. Weird.
Old 03-02-2013, 10:23 PM
Hmm. I'll have to take a look into that. My knowledge on posi systems isn't advanced so I assumed that the 4x4 did its part not needed posi. Would adding posi as an upgrade effect any gas mileage or act as a pro/con in comparison to how my truck currently stands?
Old 03-02-2013, 10:24 PM
kxlexus kxlexus is offline
Vehicle: 2013 Laramie 4X4 Quad Cab
Trim Level: Laramie Hemi 8 Speed
Color: Maximum Steel Met.
Rep:25
kxlexus is on a distinguished road
Agreed. I have been buying 4X4 trucks since 1980 and everyone of them has had a form of anti-spin differential. It is one of those options that cost little new but a lot to add later. Proper gearing even more so. I ordered the 3.92 gears even though I am getting the 8speed transmission. I would have went with 4.10 gears if they were offered.
Old 03-02-2013, 10:44 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
if you can change it get the 3.92's and the anti spin, worth it and cheaper now then down the road
Old 03-02-2013, 11:35 PM
BigHornCAP BigHornCAP is offline
Vehicle: 2013 Ram 1500 CrewCab 8R70
Trim Level: BigHorn
Rep:18
BigHornCAP is on a distinguished road
Here my take on limited slip rearends, having driven both non and locking rearends up here in canada.
with a non-locking (non limited slip, non posi, choose your name) rearend in slippery conditions moving in a straight line, One rear tire will spin, most likely kicking the rearend to the passenger side, then eventually getting started.
in a locking, (limited slip or posi) rearend in the same situation, both rear tires will spin, more than likely staying in a staight line, and gettting you off the line safely.
even with 4x4, the rearend will still slip to the side with a non-locking rearend, although it usually isn't as extreme.
there are other situations such as off-roading, where having power available to 4 tires is needed. 4X4 without limited slip rearend is a bit of a misnomer, since in full spin only 3 tires will be spinning full speed.
personally i don't see the point to non-locking rearends, but i assume there might be some fuel savings in straight lines in non-slippery conditions.
i quantify this with that i am no mechanic(weekend warrior), this is just based on my driving experiance
Old 03-03-2013, 02:36 PM
s1000rrhp s1000rrhp is offline
Vehicle: 2013 Dodge Ram
Rep:13
s1000rrhp is on a distinguished road
Get the limited slip and 3.92 would never be without
Old 03-03-2013, 08:56 PM
Ya but I heard that the bigger axle ratio you go, aside for heavier towing capacity, kills the gas mileage. I don't really tow as it is anyway and can't see me towing over 7-8,000 pounds anytime soon.
I believe my axle ratio is the 3.21 along with my 8-speed air ride V8.
Other than towing, why go a bigger axle ratio and how beneficial down the road would the posi upgrade really do for me seeing as how I have the 4x4 ready options.
Old 03-03-2013, 09:04 PM
needham needham is offline
Vehicle: ram
needham is on a distinguished road
correct the 3.92 gears will get get less MPG
the 1500s come stock with 3.55
I know guys with 2011 rams that have 3.21 gears in them and MPG are fantastic
Old 03-03-2013, 09:09 PM
Bhbdvm's Avatar
Bhbdvm Bhbdvm is offline
Vehicle: 1500 Hemi/8 Speed/3.92
Trim Level: Laramie/RamBox/Air
Color: Black gold pearl
Rep:29
Bhbdvm is on a distinguished road
I think the 3.92 has a negligible impact on mpg, especially with the 8 speed. It is also quicker off the line and then the obvious choice for towing.
