Old 02-28-2013, 07:27 AM
gonefishin776's Avatar
gonefishin776 gonefishin776 is online now
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Default Got moisture in my headlight, will it dissipate by itself?
So my little offroad adventure I splashed a shit ton of water up on the left front of my truck, and I guess some water got in because now I have some condensation. Once it gets warm and sits in the sun will it go away on its own?
Old 02-28-2013, 08:09 AM
Rep:1885
The thing about components that are designed to keep water out is that they're also good at keeping water in. I had this happen with a set of aftermarket tail lights one time and I had to remove them, take out the bulbs, blow out as much of the water as I could with compressed air and then let them sit in the sun for a day. After that, I resealed the seams with clear silicone, reinstalled them and never had another issue.
Old 02-28-2013, 08:19 AM
Rep:1900
awesome. Well it doesn't really bother me that much, so I'll wait and see what happens when it warms up. and if it doesn't go away then I'll do that. Thanks for the response
Old 02-28-2013, 08:28 AM
TimW's Avatar
TimW TimW is offline
Vehicle: 2012 Dodge Ram
Trim Level: sport
Rep:161
One of the sets I bought for mine used to get moisture in, it never left, I put them away and went with the recons, when I pulled out the bad light the other day I noticed that it was now stained inside, the light will now have to be baked in order to save it
Old 02-28-2013, 08:42 AM
Rep:1900
AHH you're killin me smalls. I was really hoping it'd just go away haha, wishful thinking. I guess we'll see. Maybe an excuse to get projectors n HIDS
Old 02-28-2013, 07:16 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
I wouldn't wait to see what happens. Bake in the oven for 15mins at 200deg. If its still there, open it up, wipe dry, close it up, bake for another 15mins, and tighten it all up. You can do as RamTech says and add another bead of silicone to the seam for good measure against it happening again.
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 03-08-2013, 09:58 AM
Rep:1900
sooo the other day i went out and noticed no more moisture....yayyy. just gotta be careful with it now because obviously it enter easily and escaped easily. I'll keep an eye on it.
Old 03-08-2013, 10:32 AM
Rep:1885
It's going to happen again. Might as well fix it now.
Old 03-08-2013, 10:40 AM
Rep:1900
you're right, your're right. A project for another nice day.
Old 03-08-2013, 10:57 AM
Rep:1885
Look on the bright side (no pun intended), this is a good chance to mod the lights if you ever wanted to do so.
