Old 02-28-2013, 10:54 AM
den052 den052 is offline
Vehicle: 1998 Ram 1500 5.9L
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
den052 is on a distinguished road
Default 1998 Ram 5.9 won't run.
I cannot get my 1998 5.9 to run. Has 29000 miles on it. It spins but won't fire. I get 1/2 inch spark at the spark plugs. Looks like a strong spark. Have tried spraying fuel into throttle body. Plugs look clean and gapped abt .040. Was thinking fuel pump but engines with bad fuel pumps I can get to momentarily run by spraying fuel into intake.
I am a GM mechanic and this one has me stumped. Basically has spark and fuel but won't fire.
Thanks, Dennis
Old 02-28-2013, 10:56 AM
Pulled spark plug wires off sparkplug and can get a spark from plug wire with a screwdriver to jump about 1/2 inch max at spark plug wire end?????
Checked for OBDII codes and there are no codes showing!
Old 02-28-2013, 12:49 PM
LRS360's Avatar
LRS360 LRS360 is offline
Vehicle: 1997 Dodge Ram
Trim Level: 1500 Laramie
Color: Green
LRS360 is on a distinguished road
Check the Crank Position Sensor. I've heard of people having the same problem with good fuel and spark.
Old 03-01-2013, 09:30 PM
jaymez34 jaymez34 is offline
Vehicle: 1999 dodge ram 1500 sport p/u
jaymez34 is on a distinguished road
Dennis,
Look at my post I made on 2/25 on a 1999 1500 P/U wont start. The crank shart postion sensor is a parts store part. The Cam and solenoid are dealer parts. The cam is in the distributor cap under the rotor. The solenoid on mine is on the passenger side inner fender wall near the front. This e-bay listing has a couple of photos.
http://thethumb.ebayclassifieds.com/...d/?ad=24007886
Doug
