Old 02-28-2013, 10:56 PM
RAM. RAM. is offline
Vehicle: 2004 Jeep Grand Cherokee
Trim Level: Overland
Color: Blue
Rep:15
RAM. is on a distinguished road
Default Common Problems with 2013 rams
Hey I just thought i would share some common problems usually found during PDIs on the 2013 ram 1500s so far
1. hoods on sport models sometimes are not aligned correctly.. this is actually far more common than you would think. usually have to get the trim guy to bend them.
2. The 8.4in screen lags and wont turn on or off.
3. Im sure most of you know but if you have the LED headlights there was a recall on them for the daytime running lights not being programmed. problem fixed using witech resetting customer mode.
4. condensation in headlights.. I have been told its normal
5. sometimes (rarely) the automatic up for windows wont work..
6. The air ride sometimes doesnt work. Still waiting on chrysler to solve this..
Just thought i would share. Im sure you guys will never see these problems but there is always some trucks that get past PDI inspections.. lots of lazy techs..
Old 02-28-2013, 11:14 PM
merve04's Avatar
merve04 merve04 is offline
Vehicle: 2013 Ram CrewCab
merve04 is on a distinguished road
1. I thought i noticed something, but doesn't seem like its enough to really tell its out...
2. Since performing the reset its been good. Although one day I lost audio on all sources but it seemed the system got hung up on reading the usb stick and my impatience of pushing buttons didn't help.
3. My LED lights are always on, even when I put it on O and driving, still on.
4. Haven't had that issue.
5. Its winter, haven't used windows much, but thus far went up auto when I tried.
6. Air suspension has been flawless.
RAM!
Old 03-01-2013, 07:18 AM
Ford Apostate Ford Apostate is offline
Vehicle: 2013 1500 4x4 CC 5'7" Rambox
Trim Level: Longhorn/8 Speed/Air
Color: Mineral Gray
Rep:17
Ford Apostate is on a distinguished road
Where are you hearing about air suspension problems? I have not heard of a single one other than some people not being able to order them.
Old 03-01-2013, 07:27 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
my 8.4an lags like a sonuvab!tch... even the reverse camera freezes for a millisecond or two every second or two, kinda patchy
Old 03-01-2013, 10:31 AM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
I'm curious on air suspension issues as well...any more details? What's the word on all the radio problems?
Old 03-01-2013, 10:44 AM
Sblann Sblann is offline
Vehicle: 2013 dodge ram big horn quad
Trim Level: Big horn slt
Color: Copperhead pearlcoat
Rep:26
Sblann is on a distinguished road
700 miles so far only issue is the vibration or buzzing feeling in steering wheel and gas petal at 2000 rpms. And gas milage is terrible but I knew that before buying truck. everything else so far is working
Old 03-03-2013, 09:18 AM
Kylekillerk Kylekillerk is offline
Vehicle: 2013 ram 1500 Laramie with air
Kylekillerk is on a distinguished road
Default Air suspension problem
Hey my Laramie hasn't had any of the other issues except some with the air suspension-
Biggest problem is when in entry mode and driving out of a parking lot the drivers tire rubs the inner fender pretty bad, they have replaced the inner fender and same issue- as I live in northern Ontario I'm worried of ice building up and breaking something but the shop seems to be out of ideas already.
Other issue is very occasional the system says "to hot wait for it to cool" now seeing as its been -30 each time that's happened not sure how its to hot lol..
Old 03-03-2013, 10:08 AM
Color: Mineral Gray
Rep:17
Does the tire rub in entry mode when you're going straight or only when you're turning?
Old 03-03-2013, 10:13 AM
Default Tire rub
Only while turning, when in normal mode if I'm turning left and hit any bumps it rubs as well- but not to bad just enough to once and a while hear it.
Entry mode sounds like your dragging something around lol
Old 03-03-2013, 10:14 AM
Rep:1890
Since when is condensation in the lights normal, let alone acceptable?
