Old 03-03-2013, 11:28 AM
13expresser 13expresser is offline
Vehicle: 2013 Ram
13expresser is on a distinguished road
I noticed condensation in my lights two days after I bought it, like RamTech posted, I do not think this is normal, the assembly should be water-tight. Does anyone know if this a '13-only issue? Or is it common among the 4th Gen trucks?
Old 03-03-2013, 12:39 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Seems to be a 2013 thing, many think its cause of the LED's, they replaced the regular Front position lamps (parking lamps, standing lamps)whatever you want to call them with LED's, it is thought that these do not generate enough heat like halogen incandescent bulbs, so the inside of the headlamp unit is never warm enough to rid it of condensation. I thought I was going to have the same issues on my 2012 headlamps that I made with projectors and LED's, but I have had them on for 3 weeks now and nothing, no condensation to speak of, and I have been watching them. Also, when i took these apart to install the projectors, at the top there are 2 vent holes with very fine screens on them, you can flash a flashlight through them and you see the light from the other side, this tells me vents for heat to move out of the lamp unit but not let humidity back in. Just an observation, but still, don't think headlamp units should have condensation in them, after a few years they will look like crap. JMO
Old 03-03-2013, 02:40 PM
Sami6 Sami6 is offline
Vehicle: 2013
Trim Level: 1500 Express
Color: Pearl Blue
Sami6 is on a distinguished road
Originally Posted by RamTech View Post
Since when is condensation in the lights normal, let alone acceptable?
That is about as acceptable as my temp being 8 degrees off and RAM can't do anything about it. 500 miles on the truck
Old 03-03-2013, 02:44 PM
Grubrunner's Avatar
Rep:3883
Outside temperature?
Grub out!
Old 03-03-2013, 08:06 PM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
Hummm? My outside temp is about six to eight degrees lower than it should be.
Old 03-03-2013, 08:36 PM
Grubrunner's Avatar
Rep:3883
What are you comparing it to, to determine that it's off by eight degrees?
Grub out!
Old 03-03-2013, 08:55 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Vehicle: 2014 6.4 Hemi; traded 2013 CTD
Trim Level: Laramie Crew 4x4
Rep:139
The air suspension issue concerns me...why the heck would it be rubbing in entry mode. I regret ordering air ride. I can't level my truck like grubrunner!
2014 2500 Laramie Crew 6.4 Hemi, 4.10 axle
2013 RAM 2500 Laramie Longhorn, Cummins, Western Brown (traded)
Old 03-04-2013, 08:06 AM
gusman's Avatar
gusman gusman is online now
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
Comparing it to the actual temperature outside. My 08 ram was the same thing. Completely unacceptable.
Old 03-04-2013, 08:50 AM
Grubrunner's Avatar
Rep:3883
I firgured that much.
What I meant was what tool exactly are you using to measure the outside temperature to determine the EVIC readout is off by your claim?
My EVIC temp readout is also off. When I used an outside wall mounted thermometer we have on our deck [THIS], it was only a degree off; sometimes on par. When I compared to to an App I have on my phone, it was off by almost 6-degrees at times.
Grub out!
Old 03-04-2013, 08:59 AM
Vehicle: .
Rep:4371
Same here, if I check my outside temperature unit in my yard to my trucks, It is usually spot on or near it when I first start my truck during the day.
