Old 03-13-2013, 03:53 PM
gto90 gto90 is offline
Vehicle: 2013 Ram
Rep:17
gto90 is on a distinguished road
Delivery of my parts to fix my trucks 8.4an
Problem got pushed out a 4th time after being
assured last night from a Ram case manager that
They would be there today.
Old 03-13-2013, 03:57 PM
GoalSK8R GoalSK8R is offline
Vehicle: '13 Laramie 8-Spd (inspection)
Color: Maximum Steel
GoalSK8R is on a distinguished road
Originally Posted by Scooped View Post
I am very curious about this area as well. The aftermarket will have a field day once they hook into architecture. I see the EVIC especially useful for many areas outside of what its doing now.
From my understanding the base OS will be/or is QNX which is being used in the new Blackberry Z10. This has a two fold effect and opens up a whole world for app developers for automotive related consumer wants and expands QNX app selection which right now is very weak when compared to iOS or Android.
To all my fellow Canadians who are upset about not having apps for our market, they are coming - if not by the carriers then by the aftermarket.
I did find an older article on the high level architecture: http://www.sae.org/mags/sve/SAEWC/9495 and I registered on the QNX development site but hadn't gotten beyond the registration. Looks like you will need to tie into the CANbus to read. I would like to research what the LockPick is actually doing and if there are ways to subscribe to all messages on each bus then filter out the ones I don't care about at the moment.
Old 03-13-2013, 05:52 PM
Driver72 Driver72 is offline
Vehicle: 2014 Laramie CC 4x4 8spd 3.92
Color: White w/ Blk interior
Rep:69
Driver72 will become famous soon enough
Originally Posted by gto90 View Post
Anyone else have the anti-spin (limited slip) rear end?
I made a uturn with my Ram and instead of backing
Up and then going forward I just pushed through the snow bank
With my passenger side. As soon as the rear tire got in the snow
I was stuck. The drivers side was still on tar, I should've been able to push
Through. Or at least the traction control should've kicked in on
The tire that was spinning even without me pushing the gas pedal..
Is the limited slip really more of a mostly slip rear end? And
Why didn't the traction control kick in?
I wouldn't get one without it.
It shocks me to see how many of the Ram trucks on dealer lots DON'T have the LSD.
It's a cheap option and worth every penny and then some to actually have power going to more than just the passenger rear tire.
I drove a non LSD one today and from a stop, pounding the gas, all you got was some tire spin on the right rear tire.
407 lbs ft of torque all going to one tire on a truck where most of the weight is over front and not enough on the rear.
Retahhhded not to have the LSD option.
2014 Ram 1500 Laramie CC 4x4 with LSD and 3.92's
2013 Ram 1500 Laramie CC 4x4 with LSD and 3.55's -GONE-
Old 03-13-2013, 07:58 PM
crabjoe crabjoe is offline
Vehicle: 2014 Ram 3500
Color: Maximum Steel Matallic
Rep:62
crabjoe will become famous soon enough
LSD will act more like an open diff, most of the time. If you're in a situation where you need traction to both wheels, apply your brakes a bit, to even out the pressure, and give it gas. That should get power to both wheels....
Old 03-13-2013, 08:24 PM
Vehicle: 2013 Ram
Rep:17
I guess I was assuming the traction control would have at least sensed
that the wheel was spinning and took care of that for me? Im lazy lol
Old 03-13-2013, 10:54 PM
MeanieNJ MeanieNJ is offline
Vehicle: 2013 Ram
MeanieNJ is on a distinguished road
Mine has an open rear. Prob going to put a trutrac in it at some point which im pretty sure can only be installed in open rears. LSD's are better then nothing but their function really is stupid.
Old 03-19-2013, 10:24 PM
Vehicle: 2013 Ram
Rep:17
Just thought I'd give an update on my sport.
I had it in to the dealership this last weekend
And Monday they replaced the radio-computer
Or whatever. I picked it up today and I still had
Issues with the USB not playing, even though
The radio showed it was. (Volume was in fact
Turned up :| ) also lost my Bluetooth connection
For my phone twice, and 2 times while I was
Trying to stream music. And of course the temp sensor.
Seems the issue must be somewhere else... Maybe
A bad ground connection somewhere?
Old 03-20-2013, 11:00 AM
lgsw44mag lgsw44mag is offline
Vehicle: 2012 Ram
Trim Level: Crew cab Sport pkg
lgsw44mag is on a distinguished road
I have the same issue with my 2012 Ram Sport. Did you find out what was causing your problem with the vibration at 2000 rpms?
Old 03-20-2013, 02:29 PM
Otterdriver's Avatar
Otterdriver Otterdriver is online now
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Originally Posted by Kylekillerk View Post
Hey my Laramie hasn't had any of the other issues except some with the air suspension-
Biggest problem is when in entry mode and driving out of a parking lot the drivers tire rubs the inner fender pretty bad, they have replaced the inner fender and same issue- as I live in northern Ontario I'm worried of ice building up and breaking something but the shop seems to be out of ideas already.
Other issue is very occasional the system says "to hot wait for it to cool" now seeing as its been -30 each time that's happened not sure how its to hot lol..
With all due respect, living in Ontario with all the salt they dump every winter having all that salt grinding into moving parts for the air suspension and all the wide fluctuations in temperature and humidity, the idea of air suspension just makes me cringe. Living in the lower 48 where temps are more constant is one thing but hopefully this doesn't become total grief for you.
Old 03-20-2013, 02:38 PM
Rep:160
Originally Posted by RAM. View Post
Update to the air suspension problems I have seen. Chrysler has said it is just something with the electrical and there is a patch coming out for it tommorrow. Ill find out if it fixes it tommorrow.
Just ELECTRICAL.....
