Old 03-01-2013, 12:44 PM
TundraKoup TundraKoup is offline
Vehicle: 2012
Trim Level: Outdoorsman
TundraKoup is on a distinguished road
Default Crew cab + 6.4ft box canada
Any idea when the crew cab outdoorsman with the 6.4 ft box will be available in Canada?
Also for those of you with quad cabs, is there a big difference in space between the crew can and quad cab?
Thanks
Old 03-01-2013, 12:57 PM
smokey988's Avatar
smokey988 smokey988 is offline
Vehicle: 2013 Ram Laramie CC 4X4
Trim Level: Laramie CC 4X4
Color: Maximum Steel Metallic
smokey988 is on a distinguished road
Thanks
The difference between the Quad and Crew cabs is quite a bit. It would depend on what exactly you plan on using the back seat for. Check out your local dealership and you will see the difference immediately. As much as I wanted the 6'4", the larger cab was a priority and time to wait for the 6'4" on the crew was not an option.
The Crew Cab with 6'4" Box (DS 91) is expected to start production 04/15/13 but nothing saying what trim levels this will be available on or if it will be on restriction like a lot of the other items on certain trim levels.
Old 03-01-2013, 01:01 PM
smokey988's Avatar
The Crew has an additional 6" of leg room. Canadian Ram Spec sheet is attached.
Old 03-03-2013, 01:21 PM
Vehicle: 2012
Thanks for the info guys.
Ill be pretty disappointed if the outdoorsman is not offered in a v6 pentastar, crew cab with the larger box on it. 5.7 ft box is too small for my needs.
Old 03-04-2013, 12:07 AM
moulin6801 moulin6801 is offline
Vehicle: Ram1500
Rep:14
moulin6801 is on a distinguished road
Same here. I can't wait for the crew cab long bed to arrive in the US!!
Old 03-04-2013, 09:23 AM
Ford Apostate Ford Apostate is offline
Vehicle: 2013 1500 4x4 CC 5'7" Rambox
Trim Level: Longhorn/8 Speed/Air
Color: Mineral Gray
Rep:17
Ford Apostate is on a distinguished road
I find it interesting if not suspicious that Ram has not shown a long bed crew cab 1500 to anybody yet. They were showing the 8 speed Hemi to the press long before they were building them. Where's the early build/prototype?
Old 03-04-2013, 10:35 AM
smokey988's Avatar
I'm not sure how they will be able to build the longer wheelbase/6'4" bed when they can not manage to complete the orders they currently have in a timely matter.
