2002 1500 nothing in cluster working - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 03-01-2013, 02:29 PM
racecase16 racecase16 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Molten red
racecase16 is on a distinguished road
Exclamation 2002 1500 nothing in cluster working
We have an 2002 ram 1500 QC 4WD w/4.7 auto. Security light stays on solid. Nothing else in cluster works. Also has no wipers, turn signals or brake lights and power locks don't work. Starts and runs fine. I've cleaned the plugs under the power distribution center, and done computer reset by taking battery cables off and touching them together. Is there anything else I can do before replacing the cluster? Any advice appreciated.
Old 03-01-2013, 04:46 PM
Resident Technician
Rep:1915
Check for power and ground operation going to the cluster and scan the PCM for a loss of comms code to the cluster.
Old 03-03-2013, 04:42 PM
Color: Molten red
I had already did the PCM test with no codes showing. I also tried the actuator even though the odometer readout wasn't working, no luck there either. I'm thinking bout taking the cluster out of my personal 04 1500, but don't want to take the chance of screwing it up too.
Old 03-04-2013, 11:58 AM
Resident Technician
Rep:1915
Actuator? You've lost me... I'm starting to think you have a bad FCM.
Old 03-05-2013, 09:24 PM
Color: Molten red
Yes actuator test. I tried to put the cluster through the self-diagnosis. I did it to see if the odometer readout would work at all. But still nothing works on the cluster except the security light. I haven't had a chance to check power and ground for the cluster yet. By FCM are you refering to the something in the cluster? I am going to do a VIN search to find out if the truck came factory with security and/or remote start. We haven't been able to ask the customer since he's out on the road. I'm leaning toward needing a new cluster.
Old 03-06-2013, 09:21 AM
Resident Technician
Rep:1915
You mean the cluster self-test. Gotcha. The FCM is the front control module attached to the IPM under the hood. My first inclination at this point would be the cluster if the powers and grounds check good.
Old 03-15-2013, 06:01 AM
scha0058 scha0058 is offline
Vehicle: 2002 Ram 1500 4x4 Auto Reg Cab
scha0058 is on a distinguished road
I have had the exact same problem, turned out to be the ignition switch, well not the switch per say, but I lost power on one of the acc wires to the switch, In my case the fuses were good so i'm thinking a break in the wire somewhere between the switch and the fuse box, i had to jumper power from second accessory wire. the proper thing to do is find the break or replace the whole wire, but the jumper did work for me
