Old 03-01-2013, 09:24 PM
mach142 mach142 is offline
Vehicle: 2003 dodge ram 3500
Color: blue
mach142 is on a distinguished road
Default 2003 3500 needs front ujoints, Again!
This tuck is stock. under 75000 miles. Original's were replace under warranty at around 50000. Now I am getting that familiar clicking noise coming from the Drivers side wheel. Dealer said the replacement ones were not the stock ones they had failures with. So my questions. Is this a common problem with this year truck? Is there a better replacement part? OEM doesn't seem to be working for me?
Old 03-02-2013, 08:03 AM
Rep:1909
I would be more inclined to blame a faulty installation of the last set as opposed to the joint itself but without seeing it, it's hard to say for sure. If you do go with an aftermarket joint, choose a brand with grease fittings.
Old 03-03-2013, 02:11 PM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:108
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
X2, I'd look into Dynatrac hubs or something like that. I know when mine go that's what I'm doing for sure. www.dynatrac.com
Old 03-04-2013, 09:22 AM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
Its a common problem, but I can't really tell you a brand that is any better. You might check on some of the Cummins forums, its a common topic.
