Vibration Noise Solved - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 03-02-2013, 09:25 AM
surcy surcy is offline
Vehicle: 2014 Dodge Ram Limited
Trim Level: Laramie Limited
Color: Bright Silver Metalic
surcy is on a distinguished road
Default Vibration Noise Solved
As info:
I had an annoying vibration, almost a humming noise in the rear of my 2012 5.7 Ram Limited with ram boxes since new. It only occured when accelerating from stop up to about 15-20 mph. It did not occur over bumps, etc----only when accelerating with engine under load.
The dealer checked the truck ( for several hours, multiple techs, service mgr.) and could not find the source. I tried on numerous occasions to find something that could be loose, vibrating, rubbing, etc. with no success. By the way, my dealer has an excellent service department.
I found the source of the noise yesterday by accident. I was climbing into the bed of the truck, bumped the tail gate, and heard the noise. ( Both the dealer and I had checked the tailgate, but did not find the noise .) It had to be hit a very specific way to duplicate.
The source was the torsion rod ( my nomenclature and I assume assists in shutting the tailgate) that runs the length of tailgate at the bottom. The tail gate had to be hit a certain way that would cause the torsion rod to vibrate. As it vibrated, it was hitting something inside the tailgate and thus the noise.
( As the truck accelerated, the vibrations or harmonics caused this rod to vibrate and thus the noise I was hearing).
I could not access inside the tail gate in this area to determine what the rod was hitting, so, instead, I placed foam rubber around the rod through a small access hole at the bottom of the tailgate to stop the vibration. It worked-------the noise is gone!!!!!!!
Old 03-02-2013, 10:14 AM
rambighorn2012 rambighorn2012 is offline
Vehicle: 2012 dodge ram
Trim Level: big horn
rambighorn2012 is on a distinguished road
Thanks for the info
Old 03-02-2013, 06:35 PM
Edokdyshi's Avatar
Edokdyshi Edokdyshi is offline
Vehicle: 2012 Ram 1500
Rep:143
Edokdyshi will become famous soon enoughEdokdyshi will become famous soon enough
I hope ya didn't block up the holes on the bottom that allow for drainage of any water that may get inside the tailgate.
18" Magnaflow muffler, 5% tint all around, multiple blacked out parts, de-badged, Westin Bull Bar, K.C. Long Range SlimLites
Old 03-02-2013, 07:32 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
Great info to know! Could you send a pic?
Old 03-02-2013, 07:36 PM
The bottom of the tailgate has a water escape provision (drain hole) in addition to the access portal.
Old 03-02-2013, 09:01 PM
DodgerocksHM's Avatar
DodgerocksHM DodgerocksHM is offline
Vehicle: 2012 Dodge Ram
Trim Level: Laramie Crew cap 4x4
Color: True Blue Pearl
DodgerocksHM is on a distinguished road
Amazing way to find the issue, good for you and thx for sharing
Old 03-03-2013, 08:24 PM
ramfan05 ramfan05 is offline
Vehicle: 2012 Dodge Ram 1500 5.7 CC
Color: Dark Gray
Rep:24
ramfan05 is on a distinguished road
Could you take a picture of what exactly you did? I have this exact same annoying noise but it happens more often than just the 15-20 mph you were talking about
Old 03-03-2013, 09:52 PM
Edokdyshi's Avatar
Rep:143
I know, but he said he went thru a hole in the bottom.....it may have been a drain hole.
