Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 03-02-2013, 06:08 PM
08RAMSLT 08RAMSLT is offline
Vehicle: 2008 Dodge Ram
08RAMSLT is on a distinguished road
Default What to check when 4x4 service light comes on
My 4x4 service light clicked on. When I come to a stop it makes a jolt from the rear end. What should I do? Is my tranny gong? How do I check my diff fluid levels
Old 03-03-2013, 09:30 AM
Resident Technician
Rep:1909
You need to get the truck scanned for diagnostic trouble codes. If your transmission were having a problem, you'd get a check engine light and not a 4x4 light. Check the diff fluid levels by removing the fill plug; the fluid should be withing 1/4" of the plug.
Old 03-04-2013, 12:28 PM
Ok, I need to replace the egr valve because that's the code it's throwing. I will check the diff fluid level this evening. If the diff level is under a 1/4" can I just add more to top it up? What kind of fluid should I add?
Old 03-04-2013, 02:19 PM
Resident Technician
Rep:1909
Yes, you can just add 75W-140 synthetic, but if it is low, you need to find out where it's leaking from.
Old 03-07-2013, 12:34 PM
Hawgjo Hawgjo is offline
Vehicle: 2011 Dodge Ram 6.7L
Color: Forest Green
Hawgjo is on a distinguished road
Default Service 4wd light on dash
Me too 2011 3500 4X4. Rear differential "jolts" on occasion preceded
the dreaded "light" on dash. Just back from local dealer here in AZ. I now quote from the service invoice. "Pulled Code P2201 FDCM Internal Failure.
Replaced Final Drive Control Module and verified repair."
Covered under warranty at 40800 miles.
Good Luck!
