Old 03-03-2013, 09:09 PM
semlohde's Avatar
semlohde semlohde is offline
Vehicle: 2014 RAM Laramie LongHorn Mega
Trim Level: LaramieLongHorn Mega
Color: bright white
semlohde is on a distinguished road
Default Read tire pressure from tire gauge or evic
My door says front tires 60 and back at 70. The evic is close and gives OK within range. Checking a tire gauge the difference is just a few pounds so I fill to 60 front and 70 rear cold tires by the evic - but i drive about 2 miles for the evic to read the tires right. Hook up the 5th wheel and roll and the tires warm and pressure rises 3-6 degrees. The question is - should I fill the tires low 5 pounds (or a few pounds less) to allow for the warming.? Everything I find says fill to the door rating when cold and nothing addresses the extra pressure as the tires warm. Hate to put 11,500 pounds on under inflated tires!
Thanks. Ed
Old 03-03-2013, 09:14 PM
JPartridgekk's Avatar
JPartridgekk JPartridgekk is offline
Vehicle: 2012 Ram Big Horn
Color: Mineral Gray Metallic Clearcoat
JPartridgekk is on a distinguished road
I've always been told, and always have run with whatever the door recomends. I've pulled a lot of heavy loads with no issues, the temp of the tires will cause some changes in pressure but it's nothing to worry about. check em cold when you can and use a tire gauge to read pressure the tire sensors are close but not as good as the trusty ol'gauge.
2012 RAM 5.7 HEMI, Diablo Intune DCX, K&N cold air intake, 18" magnaflow exhaust, Carbon Fiber Shorty antenna, BAK INDUSTRIES Rollbak G2 bedcover, Spray in bedliner, XD Rockstars W/ 305/50R20 Nitto Terra Grapplers, Bilstein 5100's Set at 2.8, TGC 3/4" Rear Coil Spacer.
Old 03-03-2013, 09:29 PM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
Tire pressure is always filled/checked cold. They account for the pressure increase due to heat when they make those specs.
Old 03-04-2013, 09:28 AM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:677
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
always check pressure when cold. my evic has always been within 1 pound of the guage.
Old 03-04-2013, 10:21 AM
semlohde's Avatar
Color: bright white
Thanks for the input. Until the evic I just used a gauge when cold but started wondering as I saw pressures rising on the evic. Pressures are close but I find I need to drive just a bit to get the evic to read correctly after I add air. Thanks.
Old 03-04-2013, 11:33 AM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
Unless you have an expensive gauge that has had it's calibration verified, whose to say it's any more accurate than your evic? I would get a quality gauge and observe both.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
