Old 03-03-2013, 10:29 PM
walterwolchuk walterwolchuk is offline
Vehicle: 2012 Dodge Ram
Color: Grey
Rep:13
walterwolchuk is on a distinguished road
Default From QUAD to Projector Headlights
Hi looking at changing my Quad stock headlights to projector headlights (halos) is this a simple plug and play option. Or do I have to rewire anything? Or my second option would be just changing my QUAD's to NON Quad smoked headlights and just changing the bulbs is this a simple plug and play option??? thanks for the help
Old 03-04-2013, 12:10 AM
I push the skinny pedal
Rep:3277
It would depend on the projectors you buy, some will be plug and play, but if you want halos, then there's typically some extra wiring involved. You can look at the aftermarket for the projectors unless you want to spend twice the money and do a '13 swap.
Kurtis
Old 03-04-2013, 05:01 AM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2015 Dodge ram 2500
Trim Level: Tradesman
Color: Granite Metalic
Rep:81
be careful on some of the aftermarket lights. A lot of people are having condensation issues
2015 Ram 2500 Tradesman, 275/70/18 Fierce Attitude M/T, 18x9 ?wheels, Custom 13' OEM projectors, 55w 5k HID's, 7" premium display cluster swap, Alpine INE-Z928HD HU, RF 200s amp, 2 10" MTX subs, Factory bumper with fogs added
Old 03-04-2013, 06:38 AM
Medic860's Avatar
Medic860 Medic860 is offline
Vehicle: 2014 Dodge Ram
Trim Level: Sport 4x4
Color: True Blue
Rep:14
Medic860 is on a distinguished road
I went with a set of Spider lights with led halos. They are better then stock and alot better with HID lights. I havent pulled the trigger on those yet though. You dont want to go with the smoked duals because in my opinion you will be downgrading to a worse headlight set up. I almost bought a set of smoked duals here locally, but the output of the stock duals left alot to be desired. I probably spent close to 200 dollars in bulbs tring diffrent ones for brighter light. There are a lot of threads on here just on headlights and bulbs and HID setups. At least you are one step up in lighting performance with you quads. Hope this helps.
Old 03-04-2013, 07:45 AM
Asur Asur is offline
Vehicle: .
Rep:4373
I build my own set with Morimoto D2S projectors, as CDnoilRam said, there are some stuff you need to wire up, tape into and setup. Also will you use regular Halogen bulbs or use HID, and your turn signal, LED's or regular Bulbs, all these changes come with some setup or wiring you will need to do. You should check with Retro shop, he might be able to set u up with something thats more plug and play than other kits. Least if you have issues or don't know what to do with something you can contact them for assistance if you have them make you a set.
Old 04-16-2013, 09:36 AM
Ramona2012 Ramona2012 is offline
Color: Deep Cherry Red
Rep:23
Ramona2012 is on a distinguished road
What are the differences between the headlights in the red truck (2012 Laramie) and the blue truck (2012 Express)? Which is considered the quad headlight, projector headlight, etc.? Are there any plug-n-play mods available for the headlights with the red truck? Thank you.
Old 04-16-2013, 09:42 AM
RamBiker11's Avatar
RamBiker11 RamBiker11 is offline
Vehicle: 2011 Ram 1500
Trim Level: Outdoorsman
Rep:65
RamBiker11 will become famous soon enough
Red truck has Quad, blue truck has dual
Old 04-16-2013, 02:04 PM
Ezekielguy86 Ezekielguy86 is offline
Vehicle: 2012 Dodge Ram 1500 5.7 HEMI
Trim Level: ST Express
Rep:71
Ezekielguy86 will become famous soon enough
Red truck has quad headlights which has separate bulbs for the high and lows.
Blue truck has is a dual setup which runs a H13 bulb that does both the high and low beam. " which mean you could not run low and high beam at the same time"
Diablo Sport Intune HemiFever 93, S&B Intake, 14" Jones Full Boar, Mag Y Pipe, 180 T-Stat, Billet Catch Can, Pioneer 5500BHS, Fox Box W/ Type R, Air Lift 1000
Old 04-16-2013, 02:16 PM
SK-Ram SK-Ram is offline
Vehicle: 2014 Ram
Trim Level: SPORT
Rep:54
SK-Ram will become famous soon enough
There are so many aftermarket options for dual headlights vs quads.
If you have quad headlights are aftermarket dual projectors a direct replacement?
Old 04-16-2013, 06:56 PM
Vehicle: .
Rep:4373
nope, your going from a Quad which is a dual bulb (1 x bulb for high, 1 x bulb for low) to a Dual which is single bulb for both high and lows. But that being said, its not like you can make it fit. You just need to tap into the wiring for what you need, usually if your going projectors your going HID as well, HID with a wire harness can uncomplicate a lot of wiring.
