Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 03-04-2013, 10:47 AM
Jkhook70 Jkhook70 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Big Horn SLT
Color: Charcoal (metallic gray?)
Jkhook70 is on a distinguished road
Exclamation Compass Calibration problem 2013 Ram 1500 Big Horn
My compass is 180 degrees off. I can't find out how to calibrate it. I have a new Dodge 1500 Big Horn SLT with Hemi.
Old 03-04-2013, 12:59 PM
astroman54's Avatar
astroman54 astroman54 is offline
Rep:52
astroman54 will become famous soon enough
Two things..
1. Go into the settings in your EVIC, and that's where you tell it to calibrate.. After setting it to calibrate, you need to drive in a few circles for it to to the calibration.
2. There is the possiblity that the roof of the truck has become magnetized and needs to be demagnetized before the compass will work correctly.
Andy
Andy
2009 Dodge Ram 1500 Sport Deep Water Blue Crew Cab Hemi 4x4
Old 03-04-2013, 02:18 PM
Andy,
That's what the dealership told me, but I can't find in the settings where the compass calibration setting is. I've been all over it and can't seem to find it. Can you navigate met there, step by step? Which window is it in?
Old 03-04-2013, 11:18 PM
astroman54's Avatar
Rep:52
I can tell you where it is on my 2009 truck, and it is pretty much the same place on my wife's 2013 Durango.
Start with it in the main screen on the EVIC.
Scroll down till you get to "System Setup" press the right arrow.
On this menu scroll down to the next to last item which will be "Compass Calibration"
Press the right arrow which will start the process.
Before you do that though, make sure that you have the right zone set for the compass. This should be in your manual with a map of the zones. You need to set the zone to the area on the map to compensate for the difference between true north and magnetic north.
Andy
Andy
