Old 03-04-2013, 02:12 PM
Gainer Gainer is offline
Vehicle: 2013 Dodge Ram 1500
Gainer is on a distinguished road
Question Disableing the Seat Belt Chime
Anyone know how to disable the seat belt chime? I know about turning the key on and the seat belt being unbuckled three times method but the 2013 Ram is a push button start.
Old 03-04-2013, 02:20 PM
Asur Asur is offline
Vehicle: .
Rep:4371
If you just push the start button without hitting the brake this should put the truck in ACC just as if it were a key. Once you do the below mentioned setup, the red seat belt light will still be lit, and the EVIC will still show the alert but the chime is disabled. Also doing the trick again will enable the chime again.
Do the following to disable it:
Start with the doors closed, ignition off. fasten your seat belt. push button to ACC mode with foot off the break 2 times, watch the seat belt light. when it goes off, unbuckle re-buckle the seat belt 3 times within 10 seconds, and immediately push button to off it will chime once to tell you if this was done successfully.
Old 03-04-2013, 02:43 PM
Thumbs up works with slight change
Start with the doors closed, ignition off. fasten your seat belt. push button to ACC mode with foot off the break, watch the seat belt light. when it goes off, unbuckle re-buckle the seat belt 3 times within 10 seconds, and immediately push button to off it will chime once to tell you if this was done successfully.
This worked great but you have to press the start button twice with the foot off the break to get the seat belt light to illuminate on the dash.
Thanks a bunch for the tip!!!
Old 03-04-2013, 03:04 PM
ck20131500 ck20131500 is offline
Vehicle: 2013 RAM 1500
Color: Max Steel
ck20131500 is on a distinguished road
Thanks! Worked like a charm.
