Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 03-04-2013, 04:57 PM
Anshasi Anshasi is offline
Vehicle: 2006 dodge ram HEMI
Trim Level: Laramie 2006 hemi
Anshasi is on a distinguished road
Exclamation 7 MPG city 8 highway!!
I get 7.0 mpg city, 8.0-8.3 highway!! No matter how i drive( heavy foot on gas pedal or light foot) i am getting almost the same MPG!!!! Ive changed spark plugs! What other things should i check!?? EGR and Oxygen sensor could be the issue?? How can i know if the oxygen sensor needs changing if EGR needs changing?? Wouldnt o2 sensor work bad because EGR is bad?? Please help thanx
Old 03-04-2013, 07:21 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
sounds like you need to quit towing 20 ton loads
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 03-04-2013, 07:25 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Are you calculating those numbers by hand or using the overhead computer?
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 03-04-2013, 08:02 PM
No man im not towing anything! Im calculating numbers by both hand and overhead! Dnt know what are the things affecting mpg? Airfilter , sparkplugs changed what else could be the issue? I think its more than one factor!
Old 03-04-2013, 08:08 PM
Outlaw's Avatar
Color: Bright white
Rep:435
Rusty muffler bearing, sticky clutch belt, idk...
On a serious note...
Check wheel bearings for stickiness, injector cleaner, sticky brake calipers, MAF
[/CENTER]
Old 03-04-2013, 08:09 PM
ORT's Avatar
ORT ORT is offline
Rep:184
Dragging caliper?
Old 03-04-2013, 09:26 PM
Grubrunner's Avatar
Rep:3883
Become a Forum Supporting Member and post it in the Ask A Ram Tech section.
Grub out!
Old 03-05-2013, 05:04 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
You definitely have a problem.
I got better mpg than that in a 79 Ramcharger on 40" swampers with 4.56 gears and a 500+ HP carb'd engine (see avatar pic).
Let us know what ya find out.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
bad fuel milage, bad gas mileage, bad mpg, egr, mpg
