Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-04-2013, 09:04 PM
1990ECabSbed 1990ECabSbed is offline
Vehicle: 1990 Dodge Ram
Trim Level: offroad
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
1990ECabSbed is on a distinguished road
Default 1990 d150 318 5.2 backfiring bad
i have a 1990 d150 with a 5.2 318, and she backfires alot, i mean ill give it gas and there will be a loud as hell "pop" in the engine and the gas pedal with just fall to the floor, this happens at least twice a day at random times. and also, it takes a lot on the gas pedal to get it to move, idk what to do
Old 03-05-2013, 02:49 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
A vacuum leak can cause backfiring, but that would be constant. Could be a clogged cat converter, but I'd suspect a bad O2 sensor, possible a failing MAP sensor.
Old 05-10-2013, 11:12 PM
ez1990 ez1990 is offline
Vehicle: 1989 dodge d150
ez1990 is on a distinguished road
I would also suspect the bad o2 sensor or failing map sensor that is if your sure you have the correct firing order (had that mistake while I was learning) and the gas pedal thing could be tranny related really depending on if it is auto or manual
