Old 03-04-2013, 10:33 PM
ADA16 ADA16 is offline
Vehicle: 2012 ram 1500
Trim Level: express
Rep:43
ADA16 is on a distinguished road
Default Lt285/60r20
Hey i am going to level my truck with the bilstein 5100 set at 2.1. I am thinking about getting wrangler duratracs size LT285/60R20 with my stock rims. My question would is do i still need to reset my spedo or anything else?
Old 03-04-2013, 10:43 PM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
To be completely accurate, yes. It is a 33.5 inch tire if I remember right which would through you off some. If you aren't really picky you would probably be fine without speedo recalibration as long as you know you are a touch off.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 03-04-2013, 11:20 PM
Trim Level: express
Rep:43
Nice sounds good. Thank you!
Old 03-05-2013, 04:46 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
I had them on my 09 and swapped them onto my 13 it's less than 1mph at 65 just depends how picky your are. I am very happy with the tires on and off road.
Old 03-05-2013, 10:16 PM
Trim Level: express
Rep:43
Because the difference in tire size from stock is so small, it doesn't affect performance right?
Old 03-05-2013, 11:02 PM
MTtruckr's Avatar
Color: Stone White
Rep:50
Any time you change height, width, weight ect, you will have changes to performance. The question is how much. This tire choice should be minimal as far as that goes. And it looks good
Old 03-06-2013, 03:56 PM
Trim Level: express
Rep:43
Nice that is what i was hoping to hear! Thanks.
Old 03-07-2013, 01:01 AM
RyanJM's Avatar
Rep:67
It will lose a small amount of mpg due to extra weight and the tread over the stock car tires there come with but I didn't notice any huge difference. I reset the size on my 09 but haven't on my 13. I am happy with the look and they don't make much noise for as aggressive as they look. There not to bad in mud and loose dirt. I would recommend some mud flaps cause when you leave the mud the do throw chunks of it.
