Help! I got the HEMI tick, what the cure? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 03-05-2013, 01:01 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
Unhappy Help! I got the HEMI tick, what the cure?
Just recently I notice on cold start up, the motor is ticking. I let it warm up a little then when I accelerate I hear the tick tick tick from the motor, seems to come from the left side? It disappears once the truck is warmed up.
So what is the HEMI tick, is it valve issue, oil, broken exhaust manifold bolt?
This motor never had this issue until now.
Anything that warranty will cover, I have 71,000 kms on it (44,000 miles)
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 03-05-2013, 01:24 PM
Resident Technician
Rep:1915
It sounds to me like you don't have the Hemi tick, but rather an exhaust leak caused by a broken exhaust stud(s) at the #7 cylinder. This is a fairly common problem and not hard to fix. If you truck is still under warranty, let the dealer handle it.
Old 03-07-2013, 01:11 AM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Yep , had mine checked out today and sure enough it's an exhaust leak caused by a broken exhaust manifold bolt . They couldn't get the bolt out so they pulled the head and sent it to a machine shop, also replacing the exhaust manifold cause it warped . It's coverd under warranty , I suggest you have it checked
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 03-07-2013, 01:22 AM
Rep:2962
I had the same issue on my '09, broken exhaust manifold bolts, only the tick never went away because the exhaust manifold cracked too
When i got it back, i had the cold start HEMI tick
changed to synthetic & it all but disappeared
Old 03-07-2013, 12:02 PM
Rep:3347
The hemi tick is valve train noise and is a constant sound across all temperature ranges and rpms, you have the exhaust bolt problem, different issue altogether.
Old 03-07-2013, 12:35 PM
jj ram's Avatar
Rep:16
Thanks guys, ya for sure it's a broken bolt and manifold issue since it goes away after warm up. It certainly sounded like a ticking valve not getting oil, but now I know !!
Only problem is it's over it's 60K standard warranty, unless this is covered under power train warranty, which I doubt....
Old 03-07-2013, 12:43 PM
FDBDW's Avatar
Rep:172
They covered mine under the power train warranty , so you should be ok
Old 03-07-2013, 02:18 PM
teenRam's Avatar
teenRam teenRam is offline
Vehicle: 2014 Dodge Ram 1500
Color: The Best Color - Black
Rep:14
teenRam is on a distinguished road
I'm gald I saw this, my 2009 just started with the ticking noise right after a cold start up, but it would go away after a few minutes. Now I know what the problem is.
Old 03-09-2013, 12:18 PM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
my 2010 had a broken exhaust stud, my dealer replaced all off them under powertrain warranty @98xxx kms.
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 03-09-2013, 12:38 PM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
Does anyone know if this problem is still an issue with 2012 and 2013 models?
