Old 03-05-2013, 01:46 PM
RAM4life21 RAM4life21 is offline
Vehicle: 2002 dodge ram
Trim Level: new body style
RAM4life21 is on a distinguished road
Default Squeaking problems!?
hey guys,
i was wondering what i can do to get rid of this annoying squeaking noise! my friend and I were off roading and cross a river that wasnt to deep. But its was fine after we cross and then the next day it started squeaking. its coming from the front in the coils. when i turn the wheel it squeaks, any bump i hit it squeaks and it sounds like a 60 yr old car thats rusted! if ya have any suggestions on how to get rid of it please let me know. the squeaking is killing me!
Old 03-05-2013, 01:51 PM
Resident Technician
Rep:1909
Start by lubing all the grease fittings. If the noise persists, have someone turn the wheel while you locate the noise. Once you find it, you can lubricate or replace the component as needed.
Old 03-05-2013, 02:14 PM
what type do you recommend WD-40 or other stuff.
Old 03-05-2013, 02:46 PM
Untamed's Avatar
Untamed Untamed is offline
Color: Grey
Untamed is on a distinguished road
Tube of grease. And a grease gun.
- 3.75" RC Combo Lift - 20" Zinik Wheels - Mud Grapplers - EGR Rugged Flares - Magnaflow 14" -
- IAFF Local F-160 -
Old 03-05-2013, 03:25 PM
so just grease the crap out of it! okay thanks
Old 03-06-2013, 10:37 AM
Infantry101st's Avatar
Infantry101st Infantry101st is offline
Vehicle: 2009 Dodge Ram 1500 Laramie
Infantry101st is on a distinguished road
I have the same chirping sound while I drive and hit bumps etc. people kept saying it was my ball joint but its perfectly fine. I will have to try the grease
Old 03-06-2013, 11:15 AM
do you think that i should lube the front control arms? and could the front shocks have anything to do wih the squeaking?
Old 03-06-2013, 11:34 AM
Hemiman345's Avatar
Hemiman345 Hemiman345 is offline
Vehicle: 2010 1500 4x4
Color: Inferno Red
Hemiman345 is on a distinguished road
I had this problem on my 04 and I greased, oiled washed and cussed it to try and stop the problem. best results were to pressure wash the spring and control arm area. I bought my son a 01 and his squeaked real bad. we changed the ball joints and it cured the problem. added spring boosters to my o4 when it started and it helped so I suspect the the noise is a combination of ball joints and sagging springs.
Old 03-06-2013, 11:55 AM
Resident Technician
Rep:1909
Any moving part in the front suspension has to be suspect until you can rule it out.
Old 03-06-2013, 10:53 PM
okay guys WD-40 is a mans best friend! i sprayed the crap out of it and when i turn it doesnt squeak anymore!!! but now its just the when i hit the bumps. do ya think thats the shocks because i WD-40 both control arms!? we are close to fixing this annoying problem.
