Towing camper with 1500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 03-05-2013, 01:55 PM
cueist cueist is offline
Vehicle: 2009 Dodge Ram
Trim Level: SLT Quad Cab
cueist is on a distinguished road
Default Towing camper with 1500
I have a 2009 1500 QC 5.7l, towing a 29ft. bumper-pull camper (loaded aprox. 6000lbs). I have the towing package and 1000# WD sway control setup.
My situation is when towing, transmission temp climbs over 195F peak, but repeatedly drops to around 175F, and the bigger issue is trailer sway to the point of almost loss of control. I'm a veteran at towing trailers, but this is my first with a 1500.
Does anyone have suggestion on a transmission cooler option and what I can possibly install to suspension to stabilize this towing scenario?
Old 03-05-2013, 02:21 PM
emmyshemi's Avatar
emmyshemi emmyshemi is offline
Vehicle: 2017 Ram 1500 crew 4x4,
Color: Max Steel
emmyshemi is on a distinguished road
As far as suspension help, the air-lift 1000 air bags for the rear coil springs really helped me level the rear when towing mine. It was a easy install, and well worth the investment( under $100). A night and day difference when towing that kind of weight.
How about I put my "carbon footprint" up your liberal ass?
Old 03-05-2013, 05:54 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
I have the towing package on mine, and it has a transmission cooler. Yours should to if you truly have the towing package vice just a hitch.
I tow a trailer similar in weight (~ 6000 lbs, but only 25' long - yeah, she's old....like 1976 vintage), and when I towed it ~ 110 miles just this weekend, my trans temp never went above 130 deg @ 60 mph, and it was not flat terrain.
I think you meant 10000# on the WD hitch...LOL. I also have NO trailer sway at all when towing mine, and my truck is 100% stock.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 03-05-2013, 07:09 PM
FZBear10 FZBear10 is offline
Vehicle: 2014 Ram 1500 Club Cab
Color: Mineral
FZBear10 is on a distinguished road
How much tongue weight do you have? When there is too little tongue weight the trailer will gradually sway more and more with higher speed until it gets dangerous.
Old 03-05-2013, 11:50 PM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
I towed a similar set up with no temp problems and no swaying but I did use torsion bars. It sounds like you have too much tong weight, not sure why your trans temp is fluctuating like that.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I agree with FZBear. It sounds like the hitch isn't properly adjusted causing sway.
Old 03-06-2013, 12:02 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Vehicle: 2017 Ram 1500 Crew 4x4
Rep:1276
+3 I'm only pulling a 24' but 6000 lbs loaded with equalizer hitch and it pulls fantastic, damn thing doesn't move at all....even in a bad crosswind. Make sure you have your rig set up properly. Not enough tongue weight can cause horrific sway.
Big Red my old 2011 Sport
Old 03-06-2013, 12:05 AM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2559
This is one of several causes of sway. Large trucks (semi's) blowing by, heavy wind gusts to name a couple. Best recommendation I can make is to get a high quality anti sway & weight distribution hitch combo. I have a Hensley, the only one that guarantees no sway. Expensive yes, but the elimination of a white knuckle freak show and true peace of mind while towing makes it worthwhile.
Old 03-06-2013, 09:04 AM
Coastline's Avatar
Coastline Coastline is offline
Vehicle: 2013 Ram 1500 4X4
Trim Level: Laramie Longhorn
Rep:15
Coastline is on a distinguished road
I have also noticed if you have the tongue of your trailer up too high it will cause some sway. I agree with the others about too little weight on the tongue will cause sway as well. I had some sway in my trailer a while back and lowered the ball a couple inches and the sway went away. Hope you get it figured out.
Old 03-06-2013, 10:40 AM
KYSEAN's Avatar
KYSEAN KYSEAN is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express Crew Cab
Rep:21
KYSEAN is on a distinguished road
OP mentioned "Bumper Connection"? If that's the case, major problem and unsafe.
Trailer Hitch, Line-X Spray In bed liner, S&B CAI, Magnaflow 22" and Y-Pipe, ARE Hard Tonneau Cover
