Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
tonneaucovered.com
Old 03-05-2013, 06:34 PM
kaw550 kaw550 is offline
Vehicle: 2009 Dodge Ram
kaw550 is on a distinguished road
Default Front end noise: 4wd? Bearing?
I have had a noise coming from the front end. Sounds like it is four wheel drive. Its kind of a winding or drone that is tied to vehicle speed.
I noticed it a few days after using 4wd.
Is it posible that it is partially in 4wd? It is not binding on dry pavement so I know it is not completely in 4wd.
Could it be a wheel bearing? No griding or scratching but I know they were common issues on my '03 ram.
ANy know issues?
Old 03-06-2013, 10:23 AM
Rocky Harbour Rocky Harbour is offline
Vehicle: 2010 Dodge 1500 Ram - Quad Cab
Trim Level: TRX 4 Off Road
Color: Brilliant Black Crystal Pearl / Light Greystone Pearl
Rep:26
Rocky Harbour is on a distinguished road
Could be a bad wheel bearing and/or it also could be bad tires. I have had both issues on my vehicle. Both front wheel bearings replaced and also the original Good-For-A-Year tires were badly cupped and caused abnormal road noise. Both are common issues with this generation Ram truck.
Old 03-06-2013, 11:04 AM
Well, i am definitely having tire issues. I have been shopping online. They are cupped even though they were rotated and aligned often.
Looks like i will be doing that first.
Is the bearing replacement similar to the prior model?
Old 03-07-2013, 10:15 AM
Rep:26
I am not sure on that one. Mine was repaired under warranty.
