tonneaucovered.com
Old 03-05-2013, 09:32 PM
caap2003 caap2003 is offline
Vehicle: 2003 Dodge Ram 1500
Trim Level: 2WD SLT
caap2003 is on a distinguished road
Default grinding noise in rear differential
Hey all,
I've got a grinding noise in the rear differential and my pinion seal is leaking since oil is being slung on the aluminum heat plate on the rear gas tank. Vehicle drives fine, but the noise at low speeds is getting scary and I'm afraid to drive it. Differential hasn't failed yet, but I'm afraid it will. Could this be just a bearing problem or something worse? I'm not seeing any metal chips when I check the rear oil. Rear oil is also full. Any suggestions?
I've seen something similar posted on this before. 91,000 miles, 2003 Ram 1500 LSD.
Thanks!!
Old 03-05-2013, 09:51 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
best better get that fixed b4 she locks up on ya
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 03-05-2013, 11:54 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
do you have a stock lsd? sounds like the clutch's are wearing out and falling apart.. mine had the same symptoms...
bearing races..
Old 03-08-2013, 10:44 AM
tat2dwiseguy's Avatar
tat2dwiseguy tat2dwiseguy is offline
Vehicle: 2012 RAM 1500 SPORT
Color: Deep Cherry Red Pearl
Rep:64
tat2dwiseguy will become famous soon enough
Chefred probably has your answer but there were also failures of the clutch pack retaining clips that would allow them to move and grind away, leaving metal shavings. There was an RRT or TSB at one time, though I can't find it. I had this happen on my 03.
Either way, if it's grinding, you're in need of a rear end rebuild.
Old 03-11-2013, 12:00 AM
NBCarbone's Avatar
NBCarbone NBCarbone is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Color: Go ManGo
Rep:22
NBCarbone is on a distinguished road
Old Freddy is most probably right.. (Oh and HI FRED! :P) He's one of the 2 best backyard mechanic's I know and have ever met, really! Helped me a lot of times with my truck.
There is a very remote possibility also - this happened to me back in October and it ended up costing me almost $1000 because of Dodge's stupidity and trying to save a buck...
Check your Jesus Nut...
What I mean is the nut that bolts your rear yoke onto your pinion gear shaft and MAKE SURE it is tight and to the proper torque!
Mine came loose back in October and it came off just AFTER I had exited the freeway (where I had been going about 75 mph) and if it had happened before I got off I might not be here passing this along.
If you're heavy into wheel spinning there also maybe a possibility that one of your bearings has gone bad but those are usually on the drive wheel (if you don't have limited slip).
Here's a couple pictures of what happened to me - I have to find the picture of the gears - the Pinion had 2 broken teeth and the ring gear was chipped, couple broken teeth and worn - and I needed new clutch packs - luckily all my bearings were in great shape...
Old 03-11-2013, 03:14 AM
Rep:2737
check out your axle bearings & seals when you are checking out the rear end
one or both of your C clips may also be bad
Ram 1500 SLT Quad cab, 5.7 HEMI(R) , 3.55 differential, EGR bug deflector, Bushwacker fender flares, custom soft tonneau, Line_X, DEBO Step, Mag-Hytec
2016 Ram 3.0 diesel undergoing Mods G2 tonneau, Line-X, Weathertech mats, Mag-Hytec differential cover, , customized Nfab bars, CB radio, Autonet wi-fi router
