Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 03-05-2013, 10:09 PM
ratbastard ratbastard is offline
Vehicle: 2011 R/T - Ram
Color: Charcoal
ratbastard is on a distinguished road
Exclamation SRT brakes on 2011 Ram - 1500
Hello,
I read an article awhile back in " truckin" magazine. they put the new 6.4L in a 1500.... it was awesome. They also added some SRT - 4 piston brakes... so my question is simple..... what SRT - 4 piston brake calipers will fit on my stock 1500 Ram? I want to add engine mods but i also require big braking power...
Anyone else want SRT - 10 braking on their Hemi? Seems like a smart thing to do when your truck can do 150 mph and run 12 second Quarters...
Old 03-09-2013, 08:24 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
I read a post a few years back on DT, the guy put srt brakes on his 3rd gen 1500. search over there for the thread.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 03-09-2013, 10:22 PM
HemiLonestar's Avatar
Rep:274
Originally Posted by ratbastard View Post
Hello,
I have F/R SRT brakes on mine. What you need to do is compare spindles from an SRT (I imagine 06 would be the closest) and compare them to your to see if there are major differences mounting and alignment wise. The spacing on the mounting ears for the front brakes as much wider, plus the shape of the spindles itself is quite different (different alignment specs for the SRT vs a reg 1500). You will need completely different backing plates on your rear axle, as the ones of the Dana 60 and 9.25 are completely different (I have the Dana). I saw the Urban Ram with them on there, I was kinda curious if those were Ram SRT brakes or from an SRT Grand Cherokee.
"Big Red"
2006 Charger R/T
Old 03-13-2013, 12:16 AM
Color: Charcoal
Awesome,
thanks Big Red. I will go to the local wrecker and compare the 2 spindles side by side. I tried comparing the calipers off the srt- Cherokee.. but they were totally different.
Cheers,
Old 03-13-2013, 12:23 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
might want to do a search i dont think the 4 piston brakes fot on the r/t i think unbroken went with a 3 piston setup
Old 03-13-2013, 02:41 PM
Rep:274
I don't think there is any such thing (how would a 3 piston even work?). 20's will clear the 4 piston calipers, but that's the minimum size.
22's definitely give you more airflow (plus SRT trucks have ducting to route air to the calipers) plus better visual appeal over those calipers, especially those sexy ass R/T wheels.
"Big Red"
2006 Charger R/T
Old 03-13-2013, 03:55 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
hence the part where i said i was not sure
Old 03-13-2013, 04:47 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
This is from broken
Originally Posted by blackout11
what brakes you got and did you do a write up on them somewhere
I got the 14" SSBC front kit with 3 piston calipers and matching rear rotors.
I also have their 4 piston front calipers but they didn't clear my old wheels. I'll be swapping them those on pretty soon.
I didn't do a write up anywhere...got lazy I guess.
Old 03-13-2013, 09:23 PM
Rep:274
Ahh, ok, it's a slider. Never seen that many pistons on one side. The ones I have are fixed. I would be wary of putting aluminum calipers on a 4800-5300lb truck, that's ALOT of heat to dissipate.
"Big Red"
2006 Charger R/T
Old 03-15-2013, 01:30 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
if i needed bigger breaking, i would go aftermarket which may include a larger master cyl.
