Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2011 Dodge Ram Forum
Old 03-06-2013, 04:28 PM
brandonjansen's Avatar
Trim Level: Laramie Limited
Rep:2117
WOW! Truck looks amazing
and 410s would not be easier. Gears are gears...
Not entirely true. 4.10's will fit in to the stock diff without any machining. 4.56's will not. But either way, you still have to get a front diff from a 2011...
Old 03-06-2013, 10:00 PM
cawish33 cawish33 is offline
Vehicle: 2013 ram 2500
Color: silver
cawish33 is on a distinguished road
for the gear , the problem is for the rear you have the zf carrier and axle , on the front you have a zf front and the gear is soldered on the carrier, so for the rear diff, you have to machine the after market gear 12 bolt ( bigger bolt on the zf carrier than the 9.25 chrysler ) and for the front end , you hae to swap the entire carrier and possibly both axle for a 2011 or older, on the 3.92 it is not that bad but on the 4.56 it is way different ! hope this help
Old 03-09-2013, 12:12 PM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
nice trk man, I miss my black one. From what Ive read, 4.10s will do nothing for you, definitely go 4.56, and you can run bigger tires in the future.
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 03-09-2013, 03:14 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Originally Posted by stinkyfatpig View Post
I got 37's on my new sport and its got the 3.92 gear package but she still hates the 7's. ive never re geared a truck before. What should I swap them too.
4.56 would be a sufficient gear ratio!
Ran 4.56 on 37s on my sierra and loved it.
What he said.....^^^
4.56 at the minimum and at this point, that is the highest (numerically) we can go.
If there was 4.88 option, that is the route I would have went with my '12
But if your front diff axle is the same as the '12, as I dont see if being different, you will require another front diff axle from a '10/'11 as the gear is welded in.
THis is assuming you have a 4wd truck.
The rear will require machining to get the gear in place.
Not an easy task, but definitely worth it.
I lasted on my 37's and 3.55 (you are far better off than I was) 2 weeks before swapping the gears.
This is my first truck and was new to the whole gear changes as well.
sales@revelperformance.com
Old 03-09-2013, 03:17 PM
Revel Performance
Rep:1804
Great looking truck
The rears would be easier for the 4.10's as there is no machining but the parts will cost the same as getting it machined for aftermarket 4.56, but you will still require a new from diff axle...1) there is no factory 4.10's 2) you'll still require to go aftermarket and therefore might as well go as low (numerically higher) in gears as possible to still enjoy your ride.
But 3.92 is much better than 3.55 but I can still imagine your dismay
sorry for the pose, the only have the shot i have is the dealer photo for there website
wow crazy i gotta read into this more. are 410's easier?
Old 03-09-2013, 03:19 PM
Revel Performance
Rep:1804
Originally Posted by dodgeman70592 View Post
I' like some more info on that setup. What rubber you running, and what size spacers were used?
They are definitely Nitto Trail Grapplers and if they are 37's, they are 37x12.5x20 and spacers....? Good question...
Old 03-09-2013, 04:57 PM
Connman67 Connman67 is offline
Vehicle: 2011 Dodge Ram 1500
Trim Level: Outdoorsman SLT
Color: black/gray
Connman67 is on a distinguished road
Welll, that is a Bad ass looking truck!
Old 03-09-2013, 09:16 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
Spend your money on a Ripp supercharger, you will be happier.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 03-09-2013, 11:35 PM
Revel Performance
Rep:1804
Although this is somewhat true, you'll only be masking the issue and can still run into problems having your truck think it can lug those 37's around.
Old 03-10-2013, 07:03 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
Plus a supercharger, stock gears, and 37s is asking the trans to commit suicide.
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
