Old 03-06-2013, 12:28 AM
confuseddodge confuseddodge is offline
Vehicle: 1999 dodge ram 1500
Color: copper and gray
confuseddodge is on a distinguished road
Default Seeking Help
Hey -
I have a 1999 dodge ram 1500 2wd with a 5.2L engine that looses power as it goes up a SMALL incline, and it feels as though it is pulling a fully loaded car hauler even when it is towing an empty lawnmower trailer. I have tried the things listed below, but there hasn't been any improvement. Any help/ideas will be appreciated.
Things I've tried:
new wires
new plugs
new coil pack
new distributor cap
new rotor
removed and cleaned fuel injectors
checked fuel pressure (twice)
replaced solenoids in bottom of transmission
replaced transmission fluid and filter
replaced rearend with one that has a lower gear ratio
removed catalyitc converter
had the truck checked twice for engine codes - none present
Old 03-06-2013, 12:35 AM
Rep:2657
some members have answered on your other post
Old 03-06-2013, 01:40 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
As someone said in another post, they are known for having a leaking intake manifold gasket.
Old 03-11-2013, 12:08 AM
NBCarbone's Avatar
NBCarbone NBCarbone is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Color: Go ManGo
Rep:22
NBCarbone is on a distinguished road
Send a message via Skype™ to NBCarbone
you may want to do a compression check and also when was the last time the transmission was checked / had an oil change / change filter if it's an auto?
