Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 03-06-2013, 07:35 AM
Skull Fetish Skull Fetish is offline
Vehicle: 2012 Quad Sport 4x4
Skull Fetish is on a distinguished road
Default absorbers for lowered suspension
Good day!
Ground Force Suspension Drop Kit 9984, need a set of shock absorbers for this understatement.
regular front and rear shock absorbers from a kit, work together ugly. I would like to buy a kit for it and enjoy the under-machine, not to catch it on the road after 120 km / h
quad 2012 4x4
Thank you for your attention.
Sorry for my english, I'm from Russia.
Old 03-06-2013, 07:25 PM
I push the skinny pedal
Rep:3277
You should look at the belltech drop shocks, they're 2" shorter in the front and 3" in the rear. Part #s 2216FF and 2215FF
http://www.belltech.com/products/belltech/shocks.html
Kurtis
Old 03-07-2013, 04:04 AM
Thank you!
But it is only the rear, and I would like to change and front too.
Belteсh does shortening of the front?
Old 03-07-2013, 11:54 AM
Rep:3277
They only have drop shocks for the front on a 2wd, there is a difference. The front should only be dropped 2 inches, so the stock length will still work, just pick up a set of upgraded or quality front shocks and you'll be fine.
Kurtis
Old 03-10-2013, 12:35 PM
Thanks again for your answers and patience
The last question that would make sure that I understand correctly, all I have to buy the standard front and rear shock absorbers Belltech shortened from the above links you?
Then, if you one more question, after installing the rear suspension cars dropped to 0.5" below before, is this normal?
