Dodge Ram Decals
Old 03-07-2013, 01:06 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Originally Posted by bknife View Post
Not sure dont have them yet but the websites I have read said like 34.8, so thats not true?
Maybe mine aren't aired up completely or something but i put a piece of cardboard across the top of the tire and measured where it intersected the tape measure, and it came out to 33.75" I might re measure with a second set of hands to make sure the cardboard is completely flat, because it was kinda hard with the tape in one hand and the cardboard in the other.
Old 03-07-2013, 01:29 PM
hemipowerv8 hemipowerv8 is offline
Vehicle: 2013 Ram Sport CC 4x4
Rep:74
hemipowerv8 will become famous soon enough
The weight of the truck compresses the tire a bit...tire measurements are done inflated but not bearing weight. A better measurement would be dead center of the hub/wheel to top of the tire (radius) and double that. Most 35s are 34.5" to 34.8 - a few are actually true 35".
Mods: Tint, Line-X spray in, PD emblems, Weathertech mats, Honeycomb grille, Mopar tow hooks, Magnaflow 18" and Y, Bilstein 5100s @ 2.1" & TGC rear spacer .75", Toyo All terrains 35x12.50x20, 5" black tips, BakFlip tonneau cover, 87mm tb
Next: Gorilla lifetime lug nuts, CAI, Diablo tune.
Old 03-07-2013, 01:38 PM
Rep:1900
yeah I know that. I'm just sayin when it's all said and done and the truck is sitting there, I'm only at slightly less than a 34" tire. Doesn't matter what the size is with no weight on them
Old 03-07-2013, 02:07 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
Looks good man!
Old 03-07-2013, 02:09 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Definitely looks good
sales@revelperformance.com
Old 03-07-2013, 03:09 PM
retto22 retto22 is offline
Vehicle: 2011 Ram 1500 sport
Trim Level: sport
Rep:13
retto22 is on a distinguished road
Okay. So can I just get a quick Answer. ... was the o.p. truck accomplished by doing bilstein 5100 in just the front, or front and rear? If front and rear are you maxing all four shocks?
Old 03-07-2013, 03:11 PM
Rep:1900
just the front. I don't think they even make adjustable shocks for the rear
Old 03-07-2013, 03:13 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Yup, just the front. If you want to lift the rear you have to use a coil spacer. Most people run the Bilsteins at 2.8" (maxed). But if you're going to do that I would recommend a 1" rear spacer as well otherwise your truck is probably going to look like it's squatting.
Old 03-07-2013, 05:36 PM
Trim Level: sport
Rep:13
Awesome. Thankyoy for the replies. This forum rocks
Old 03-07-2013, 05:42 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Looks really nice
Thanks
Jeremiah
Discount Auto Performance
