Old 03-12-2013, 08:34 PM
shostopper17's Avatar
shostopper17 shostopper17 is offline
Vehicle: 2011 Dodge Ram Express
Trim Level: 1500 Express
Rep:54
shostopper17 will become famous soon enough
Wow truck looks mint good job
Old 03-12-2013, 10:55 PM
Trouse40 Trouse40 is offline
Vehicle: 2010
Trouse40 is on a distinguished road
Looks good!!!!!
Old 03-12-2013, 11:39 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Thanks guys!! I want to get some custom badges down the road. Mopar logo with hemi under it. Black with red lettering and logo. Or paint mine black with red ram head.
New audio build in progress
Old 03-13-2013, 07:54 PM
SeaSoldier SeaSoldier is offline
Vehicle: 2012 RCSB Express
SeaSoldier is on a distinguished road
I love your wheel choice. They are exactly what I was looking for. As luck would have it, they don't make them in 20" for our bolt pattern. When I wear out my stock 20" tires I will get some in 22" along with Toyo Proxis tires.
Old 03-17-2013, 06:37 AM
hodgeee's Avatar
hodgeee hodgeee is offline
Vehicle: 2012 dodge ram 1500 2x4
Trim Level: express
Rep:134
hodgeee will become famous soon enoughhodgeee will become famous soon enough
Got Proxies and love them, ride perfectly smooth, ride perfectly quite, stick like hell and after 7000 miles, they looke like the tread is still brand new. Pretty good in the rain also.
What size tires are you running on those muscle car rims?
That swagger you feel is not really from the bracket, that little off of angle wouldn't make that much difference, what you are feeling is no rear swaybar. Get the Hellwig set for the truck, and huge improvement of turn in and balance. Will completely get rid of the rear end swaying you feel now. Express trucks don't come with rear swaybars, can you believe it. The hellwigs will come with everything you need, the brackets are already installed on the truck, and your BT kit came with the shorter endlinks for the swaybar. You will need a couple of nuts and bolts from the hardware store, 4 for the swaybar mount, and two longer ones for the upper endlinks.
I had crazy swagger and odd bouncing from the rear end under sharper corners like on the freeway or at speed. The rear swaybar totally killed this, just if you get the rear, do yourself a favor and get the front bar and save time, cause after you get the rear, you will notice how lacking the front swaybar is!
BellTech 2/4 Street Performer, Spohn PanhandRod, Hellwig Sways, Volant Intake(Donaldson Filter), 85MM Fastman Throttle body, 14" Magnaflow, T1000 w/Hemifever Tune, 180 T-stat, 4.10 Gear Swap, Edge Street Perf - 2600 Stall, Billet Catch Can, E-Fan Swap, ARH LongTubes
Old 03-17-2013, 11:05 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Anyone interested in a Hellwig sway bar let me know which one you are looking for and I will see if we can get it out to you at a very competitive price
Thanks
Jeremiah
Discount Auto Performance
Old 03-17-2013, 03:18 PM
shawnu's Avatar
Vehicle: 2012 Ram
Rep:517
I am running 285/45/22 nexen roadian hp's. And its not body roll from no sway bar i am feeling, i had no left to right sway before the lowering kit was installed. The axle is pushed to the passenger side a good 1/2-3/4 if an inch. Its very noticeable. I have the bracket now, but the rain today is putting that off untill sometime later this week. Hopefully itll line everything back up, some have had no luck. I might just drilla new hole.
Old 03-17-2013, 03:19 PM
shawnu's Avatar
Vehicle: 2012 Ram
Rep:517
Oh yeah, the rims are +14 offset and with my tire size i have had 0 rubbing issues with the 2/4 drop
Old 03-18-2013, 05:32 AM
hodgeee's Avatar
Trim Level: express
Rep:134
Nice sweet, oh and by the way, I forgot, I got the adjustable Spohn panhand rod at the same time I did the BT kit. My truck was .5"s off to the driver side before I replaced the panhand rod, and with the rear axle being out of alignment, especially as much as yours was, you would probably definately feel out of alignment running odd angles on the suspension.
Thanks for the info on the rims, I saw them listed for our trucks, and was thinking of getting a set, but I wanted to stay 20", and I think you said the smallest they make for our trucks was 22" correct? So you are running a 32" tires then. They look pretty good, and 1"shorter than stock. Your speedo will be off by 1.2mph at 60 according to the wheel diameter calculator.
Old 03-18-2013, 05:34 AM
hodgeee's Avatar
Trim Level: express
Rep:134
Now, just put in a badass brake system since your rims will show them off soo nicely, and that look will be kickin!
