Old 03-06-2013, 07:27 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Default What do you think?
Im doing a hole new exhaust setup. Im putting on long tube headers and don't know what piping I should use Im going with all new stainless dumped in front of the back tire. Should I 2.5" into a Y then 3" into muffler and 3" out or doul 2.5" out?
SPONSORED BY
BULLY'S PERFORMANCE
Old 03-06-2013, 07:48 PM
I push the skinny pedal
Rep:3277
Your header should be a 3" collector, check that to be sure. Will you be keeping stock cats? If you're doing a whole exhaust, do you still want to do a y-pipe or split it and do true duals, H-pipe, and dump?
If you're doing a dump before the rear axle, I would do a 3" in, 3" out muffler, no need to split it and cause unnecessary restriction. Also check out the type of mufflers you can get, straight through ones like corse or borla are worth it if you want the exhaust flow.
Kurtis
Old 03-06-2013, 08:03 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
The headers come with high flow cat. I don't really know what would work best for performance (putting this baby on the bottle) duals with H or Ypipe???
SPONSORED BY
BULLY'S PERFORMANCE
Old 03-06-2013, 08:20 PM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2013 power wagon 2500 loaded
Trim Level: crew cab loaded
Rep:80
dwanton will become famous soon enough
should you be watching out for back pressure -- you dont want to lose power and torque .
2013 power wagon 2500 - 5.7 everything but leather.
Old 03-06-2013, 08:43 PM
Rep:3277
If he sprays off the line then losing torque will never be an issue, keeping his wheels planted will be.
Kurtis
Old 03-06-2013, 11:37 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
That's the plan! so what do yall think, 3" dual in and out with an H or 3" in with dual out with an Ypipe????
SPONSORED BY
BULLY'S PERFORMANCE
Old 03-07-2013, 11:03 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if your gonna do dual in an out and run 3" piping in front of muffler, I would keep the rear piping at 2.5".. even with my motor setup (cam an heads), that exhaust would be too big...
Old 03-07-2013, 11:07 AM
chefred112's Avatar
Rep:656
the reason I say go smaller anyways besides the scavenging effect, it will give you the option later to run cutouts right after the H later on, you'll get your free flow there..
Old 03-07-2013, 03:29 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
I hear cutouts are bad about leaking???
SPONSORED BY
BULLY'S PERFORMANCE
Old 03-07-2013, 03:32 PM
HOTRODHARLEY's Avatar
HOTRODHARLEY HOTRODHARLEY is offline
Vehicle: 2013 Ram factory order
Color: BLACK
Rep:256
HOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the roughHOTRODHARLEY is a jewel in the rough
Back pressure is a joke to us. We really don't need to be worried about back pressure. Pressure waves in our long systems make enough back pressure. Size it bigger always. 3" is a good decision for duals. and 3.5" or bigger for a single system.
Now a short system that dumps 2 feet after the header collectors will be lacking back pressure. But that's a different story....
Belltech 3"/5" Lowering kit. Belltech Rear Swaybar, Flowmaster Y Pipe, Custom 4" Single Exhaust w/ 4" Race Magnaflow, 22" SRT10 Wheels, Moroso Catch Can, Undercover SE Tonneau Cover, Weathertech Techliner Bedliner, Diablosport Trinity w/ Hemifever Tune
