Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 3.9L V6 Specifc Topics
Old 01-28-2013, 11:34 AM
changzies changzies is offline
Vehicle: 1999 dodge ram
Color: green
Engine: 1994-2001 239ci (3.9L) Magnum V6 175hp
Rep:29
changzies is on a distinguished road
Default E3 plugs
I was doing some reading using search and read a few people saying staybaway from e3 just never read why. I recently bought them so thats why im asking . If they are garbage ill return them help would be appreciated
Old 01-28-2013, 11:48 AM
Rep:1385
multiple electrode spark plugs don't do anything good. You still only get one spark between one ground strap and the center electrode, and the other two ground straps only shroud the spark(reducing power and efficiency). The only "benefit" is that when one ground strap gets gunked/fouled the next one will be the path of least resistance for the spark, so from that stand point they last longer. But really the center electrode wears out first, not the ground strap.
Get a single ground strap plug, either copper(cheap, good, replace ~30k miles) or a single ground strap iridium plug(more expensive, but is good and lasts ~100k miles. They will basically perform the same, the difference is longevity. Iridium will perform more consistent with time as it doesn't hardly wear.
Old 01-28-2013, 11:54 AM
Color: green
Rep:29
I see now thanks alot for the explanation
Old 01-28-2013, 01:45 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
good info reps for you
Jeremiah
Discount Auto Performance
