Old 03-07-2013, 04:06 PM
BuckWild09's Avatar
BuckWild09 BuckWild09 is offline
Vehicle: 2007 Dodge Ram 1500 Hemi 4x4
Rep:63
BuckWild09 will become famous soon enough
Default Ball Joint problems- 5100's install
does anybody on here have any tips or tricks to poppin ball joints?? Last weekend it tried installing my Bilstiens. Took off the wheel, moved the brake caliper, unbolted the sway bar link and steering link and the upper control arm, loosened the lower strut bolt. I went to pop the ball joint with a 5lb sledge.. wouldnt pop. Beat in the pickle fork.. still wouldnt pop! and had to put it ALLLL back together. Is there something im missing here or do i need to just beat the hell out of it to pop out! Im gonna give it another shot this weekend. Hopefully ill have better luck
3" Zone Body Lift--6" RCX-- Bils @ .5"-- 20x12 Fuel Hostages--37x13.5" Toyo MT
Old 03-07-2013, 04:15 PM
Rep:1909
This is what we use. Perhaps you can locate something similar at a parts store with a tool loan program. https://millerspecialtools.spx.com/Detail.aspx?id=604
Old 03-07-2013, 04:22 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:71
latitud will become famous soon enough
Don't strike on the ball joint itself, use the hammer to strike the control arm..this does the trick 99% of the time. However, your local parts store should have a ball joint removal tool..awkard to use, but works.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 03-08-2013, 09:43 AM
BuckWild09's Avatar
Rep:63
guys at autozone had no idea what i was talking about so had to search around. finally found it. got a air pickel fork, puller, and ball joint seperator tool at harbor freight! hopefully they dont break when I go to use them haha gonna try to get them off tonight after work and maybe the body lift this weekend! thanks for the pointers guys!
Old 03-08-2013, 06:49 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
A little trick I have tried. Find a nut the same size as the crown nut on your joint. Pull the crown nut off and install the sacrificial nut so that the threads arent quite all the way thru. Switch back and forth between the side of the knuckle near the offending joint and striking the sacraficial nut to pop the joint out.
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
