Old 03-04-2013, 08:25 PM
Digs25 Digs25 is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Digs25 is on a distinguished road
Default Bilstein shocks needed for 37" tires w/6" RCX?
Lift is installed and have to pull the trigger on some new treads tomorrow. Was going with the Nitto Terra 37X12.5X17 on 17X9 -12 offset wheels but I am a little worried I might have rubbing issues on the front fender/bumper. Seems in every search, anyone running 37's has the bilsteins. The 37's are only $20 more than the 35's so I would like to make them work. The Nitto's actually measure out 36.46". Anyone know if this setup will hit the fender or rub anywhere?
Old 03-04-2013, 08:51 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
I have a 6" RCX with Bilstein 5100 at 2.1" and rub slightly.
BUT I am running 37x13.50 on 20x10 wheels. So I honestly think you will be better off than me. I would get the Bilsteins just to be on the safe side. I think you would rub with 37s on a 6".
Plus Bilsteins will give you a better ride quality and also give you the ability to go higher when wanted/needed.
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 03-04-2013, 09:27 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I agree with ram725
Jeremiah
Discount Auto Performance
Old 03-05-2013, 07:28 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
you wont rub.......
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 03-05-2013, 07:29 AM
chadster21's Avatar
Rep:108
you wont rub....... his tires are only 12.5 wide he will be fine. few people are running this set up and have no issues. although i would run the bilsteins anyway
Old 03-05-2013, 04:33 PM
It will be close as it is 13.5" wide as per their site.
But I do strongly recommend Bilsteins either way.
The key offset to have zero rubbing is 0 offset on a 20x9 rim. Not many like this offset and choose to have a wider and more negative offset for a much better stance.
Old 03-05-2013, 05:32 PM
Thank you all for the feedback. I think I will go with the 35's this time and take some measurements off of them. Perhaps 37's next time.
Old 03-06-2013, 08:12 AM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Which tire you thinking about going with? If it is a Toyo or ProComp tire I'd be more than happy to get you a quote
Jeremiah
Old 03-07-2013, 05:54 PM
chadster21's Avatar
Rep:108
get 37s you will regret 35s haha... i know i did
Old 03-07-2013, 11:22 PM
Jeremiah
Thanks for the offer. Went with a local tire shop for lifetime rotation and balance. Maybe next time.
